08-13-2014, 10:29 PM | #1 |
Grounding wire????
Guys,
do i need to strip the paint in the area where the grounding wire attaches to the core support or will it be ok without stripping it down? dont know if the starr whasher will dig in and do that. there are two spots on the core, one on each side. thanks. Mando |
08-13-2014, 10:51 PM | #2 |
Re: Grounding wire????
It does make for a better connection if the metal is bare.
But, bare metal does rust and isn't appealing. I would suggest make a good clean, tight, bare metal connection, then hit it with a coat of spray paint to match the rest of the metal to keep the aesthetics clean. It won't interfere with the ground.
"Off the grid and on the seven day weekend plan" "One person cannot know everything, but between all of us, there isn't much we don't know." |
08-13-2014, 11:02 PM | #3 |
I think i would just make sure its tight. The threads are bare metal and should make a good connection.
08-13-2014, 11:07 PM | #4 |
You dont need it to be bare metal, but it helps if it is. Paint will get in the way, but for the most part it wont matter, you should be fine just tightening it down, but if it were me i'd take off the paint directly underneath the bolt head, so you dont see it and it helps with the bare metal connection
08-14-2014, 07:26 AM | #5 | |
I was just wrestling with this dichotomy the other day, as I was trying to get my trailer lights to work. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
08-14-2014, 09:14 AM | #6 |
Thanks for the info all.
I think I will go with the option of not taking it to bare metal first, but if the system decides to not like it, what would be the tale-tale signs that it wants me to take it to bare metal for better connection. Also, do i put dielectric grease on these grounding bolts, washers, loops...? Thanks again for all the help trying to put it back together. |
