08-14-2014, 01:29 PM | #1 |
Side view mirror question
My 63 didn't come with a passengers door mirror. I want to buy one from LMC. My issues is that I am worried that just screwing the mirror to the door doesn't sound too solid. Is there a backing plate that belongs behind the door that those mirrors mount to?
08-14-2014, 04:20 PM | #2 |
Re: Side view mirror question
There are factory demples on back side. Use those to locate base. I used washers and nuts to hold in place.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats http://www.cardomain.com/ride/332579...t-c-k-pick-up/ http://67-72chevytrucks.com/vboard/s...d.php?t=560081 |
08-14-2014, 04:23 PM | #3 |
Here is side view.
08-14-2014, 04:41 PM | #4 |
The factory installed backing plates in both doors, but you will need nuts and lockwashers for the install on the pass side. Position is same as driver door, so make template off of it or take measurements from it and you'll be fine. Be sure to order the exterior gasket also.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
08-14-2014, 07:31 PM | #5 |
Senior Enthusiast
I used serrated flange nuts inside the door. This helps spread the load and also makes it easier to attach to the screws as there are no washers to fall inside the door. Also, I highly recommend the outside gaskets from LMC. They are molded with a ridge around the edge and last indefinitely. All others I'm aware of are cut from flat rubber stock.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502 |
09-12-2015, 12:25 PM | #6 |
But Found Her 25yrs Later!
How's the view with the small mirror that far away.
I noticed most newer passenger side view mirrors give you more view. As in: 'objects in mirror are closer than they appear'
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 |
09-12-2015, 03:20 PM | #7 |
View? What view? Na it's ok, can see top of bed and about a foot out to side. By the way I am in Eugene working.
