Old 08-14-2014, 07:08 PM   #1
DMO
disc breaks and wheel clearance
I'm Just completed the disc break conversion from ECC on my 66 but I failed to read the small print about the original wheels not fitting. My wheels hit the new calipers. I wanted to keep the original wheels and the only solution seems to be to add a spacer? Has anyone used a 3/16 to 1/4" spacer and not replaced the lugs? If so does it leave enough thread?
Thanks for the help!!!
DMO is offline   Reply With Quote
Old 08-14-2014, 07:12 PM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: disc breaks and wheel clearance
71-87 4x4 steel wheels will work with disc brakes.
Keith
Convert to disc brakes.
Old 08-14-2014, 10:05 PM   #3
TR65
TR65's Avatar
DMO
I use 1/4" spacers for the same reason. In my case there was plenty of thread on the studs.
TR
1965 C10 SWB Fleet
Two owner
LS2 Swap Thread http://67-72chevytrucks.com/vboard/s...d.php?t=413880
TR65 is offline   Reply With Quote
Old 08-15-2014, 09:21 AM   #4
jcramsey
jcramsey's Avatar
I used a small spacer and just a touch of of the grinder on my calipers to make my stock wheels fit.
The Egg Hauler
The Government Mule
jcramsey is offline   Reply With Quote
