Old 08-14-2014, 08:50 PM   #1
JWG
does someone make an original style starter for a 168 tooth flywheel?
I'm installing a Ramjet 350 into my '65 C10. The Ramjet has a one piece rear seal so it uses a special flywheel which is 168 tooth. Does someone make an original stye starter, but for a 168 tooth flywheel, or will I have to change my flywheel to a 153 tooth?
JWG is offline   Reply With Quote
Old 08-14-2014, 09:00 PM   #2
JWG
Re: does someone make an original style starter for a 168 tooth flywheel?
or better yet... any issues with using my block mounted mini starter that's already on my ramjet with the factory bell housing that normally would use a bell housing mounted starter?
Old 08-14-2014, 09:13 PM   #3
JWG
actually I just found some info online that answered my question
The cast iron bellhousings with flange mounted starters can be used on all V8's 1962-on. These can be used with block mounted starters by grinding the lower portion of the housing to clear the block mounted starter casting.
source:
http://www.novak-adapt.com/knowledge...shift_info.htm
