1958 Chevy Apache w/348 Questions
I recently bought a 1958 Chevy apache with a 348 big block. It has the original cab and fenders, a 1-ton dually rear end, and 4 on the floor. My question is, did Chevy Apache's come with a 348 from the factory? If so, where would I look to see if the engine in the truck is in fact original. The guy I bought it from has no idea.
Re: 1958 Chevy Apache w/348 Questions
I've never heard of one, but nice find. I'm putting a 348 in my '48.
Pictures are a must.
http://67-72chevytrucks.com/vboard/s...d.php?t=592642 '48 Chev extended cab with attitude http://67-72chevytrucks.com/vboard/s...d.php?t=592769 My daughter's '46 International PU |
![]() ![]() Join Date: Nov 2008
Maybe in the Vikings but not in an Apache (1/2 ton trucks).
My Dad put first a 283 in his '59 Fleetside then later a 348 and it ran like stink. Quite the engine those "rock crushers" were!
'55 Big Window Shortbed, Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's Dan's '55 Big Window "Build" - Well, Kinda! |
I never say never but 99% sure there were no 348's in any small truck, ever. 58 was the first year for the W engine in a passenger car and it was the performance engine of the day. Put out there to compete with the Ford 352 FE engine which debuted in cars the same year. Built one for a model A last year and parts are expensive. Nice looking under the hood and there's a stroker kit from Showcars and others that will get it out to near 500 CID if you want to get frisky.
to add to speedbumps 99%...
the 348 was introduced in 58 as a truck motor, a big truck motor, the 58 3100 had factory sbc 283 but this was also the era of dealer accessories and the 348 may have come new from the dealer it may have been a 58 truck motor but it would not have been factory if it were a gmc it may have had a 336 pontiac motor in 58
cool, an ogre smiley ![]() how to put your truck year and build thread into your signature shop air compressor timer |
If it had a one ton rear end and the number on the side ie the series is higher than 32 and 31, then it is NOT an apache. Apache is the name only for the light duty trucks there were other names for the heavier ones. And yes a 348 was a factory option for the heavier duty trucks, I don't have the info at hand right now to say which ones for sure.
You could also get a Buick nailhead in '58 but only in a Chevrolet bus chassis.
If the engine is original for '58 it should have parts with '58 casting numbers. Reference info is here: http://www.348-409.com/blockcast.html Block casting number is on the driver's side rear of the engine. The date code can be found to the RH side of the casting number. ![]() http://www.348-409.com/datecodes.htm Get a shot of the door plate and/or VIN tag. |
#8 | |
here is my 1959 1 ton side spear with apache and 38 clearly visible pre 1958, 3800 is a 1 ton truck, chevy dropped the 00 in 1958, so a 1958 38 is a 1 ton apache light duty trucks (1/2 to 1 ton) were apache medium duty trucks were viking, 1.5 and 2 ton heavy duty trucks were spartan anything over 2 ton ![]()
Every 348 magically becomes a 409 when installed, just like early SBC Vette motors 8^))
1959 Chevy Short Fleetside w/ 74 4WD drive train (current project) OrrieG Build Thread 1964 Chevelle Malibu w/ 355-350TH (daily driver) Helpful AD and TF Manual Site Old Car Manual Project |
#10 | |
