Old 08-15-2014, 10:05 AM   #1
mgkgmc
mgkgmc's Avatar
Axles drilled
Does anybody know of a good place in Phoenix AZ to get my axles drilled to five lug from six lug? Or does anybody know of a easy way to do it yourself I have access to a industrial mill.
1970 GMC 1500 stepside
1972 GMC Jimmy Custom
2004 Chevy Colorado
1989 Swb Silverado
1972 Aj's Stormer
mgkgmc is offline   Reply With Quote
Old 08-15-2014, 10:21 AM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: Axles drilled
I've never had any drilled but it's my understanding that it's hard to do those because one of the original holes has to be welded up before it is re-drilled. I have read on here that the axles are available from a couple of different vendors though.
LockDoc
Leon
Old 08-15-2014, 10:25 AM   #3
mgkgmc
mgkgmc's Avatar
Re: Axles drilled
Thanks for replying I was wondering about that. Might not be worth all the trouble.
2004 Chevy Colorado
1989 Swb Silverado
1972 Aj's Stormer
Old 08-15-2014, 10:27 AM   #4
LockDoc
LockDoc's Avatar
Re: Axles drilled
No problem. Here are a couple of threads on the subject.
http://67-72chevytrucks.com/vboard/s...d.php?t=339983
http://67-72chevytrucks.com/vboard/s...d.php?t=169096
You may get some input from other members on here too...
LockDoc
Leon
Old 08-15-2014, 07:48 PM   #5
Kennuck
Kennuck's Avatar
Re: Axles drilled
If the axles are for the 70 GMC in your sig. you may already have the wider axle housing. In this case 71-72 5 lug axles are a direct replacement. I did this on my 70 C10 and it worked great. Bought the axles off EBay for $40 from an auto wrecker.
I have been told the axle shafts from the square bodies fit also but I haven't confirmed this.
1970 Short Wide
5.3 4L60E BlackBear tune
3:73 gears, Boyd's Tank
2.5 / 4 drop 5 lug disc brakes
Vintage Air
18x8 Ridlers 255/55 frt. 18x9.5 275/60 rear
Kennuck is offline   Reply With Quote
