Old 08-15-2014, 12:44 PM   #1
old cool
PCV and oil breather cap on same valve cover
I have read that oil breathers and PCVs should not be put on the same valve cover. This was particularly true on the V8. I have not found any information regarding inline 6's. In mid sixties I see pictures with and without oil cap breathers. What is correct? I have read where oil can get back into your intake when breathing apparatus is incorrect.
old cool is offline   Reply With Quote
Old 08-15-2014, 12:47 PM   #2
PGSigns
PGSigns's Avatar
Re: PCV and oil breather cap on same valve cover
On a 6 you have to put them in the same valve cover. Most pcv issues start with using valve covers with out the baffles in them and pulling oil through them. The factory covers are baffled well.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 08-15-2014, 12:54 PM   #3
66Submarine
66Submarine's Avatar
X2. Early ones use a vented breather/oil fill cap for the PCV to pull air from, and later ones (or ones that came with emissions, I guess) use a non-vented cap and have a hose running from the side of the valve cover up to the air cleaner to pull filtered air.
1965 C30 pickup 350/SM420/4.10's (daily driver) thread
1968 Impala 4 door sedan (future driver project) thread
66Submarine is offline   Reply With Quote
Old 08-15-2014, 01:08 PM   #4
old cool
thanks for quick reply. By baffles are you referring to the plates within the valve cover?how does one verify a pcv is working properly? If it looks right does that mean it is right.
Old 08-15-2014, 01:16 PM   #5
1963c-10
1963c-10's Avatar
Pull the pcv valve while the engine is running.....you should feel vacuum pulling on the bottom of it.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 08-15-2014, 01:46 PM   #6
old cool
Very strong suction as I recall. Engine got rough too. My question also had to do with right pcv. Mine is not made by gm or USA. it looks like a generic off an orielly's wall.
