08-15-2014, 06:35 PM | #1 |
A few random questions (that I didn't find answer to in the FAQs)
1. I'm replacing the Thrift Air control cable/fan motor switch in my truck. The switch I ordered from LMC has more terminals than the original, and the connector is different. The three wires that go to the resister are self explanatory, but the supplemental shop manual I recently purchased doesn't include this circuit in the wiring diagrams.
Which of the two pictured terminals takes power, and what does the other one do? 1a. Where does the Thrift Air circuit get its power? 2. How screwed up are the ends of my frame? 3. Does anyone have pictures of how the rear bumper bolts up? I have a freshly powdercoated bumper and a bunch of brackets that I don't know what to do with. Thanks, Jim |
08-15-2014, 06:53 PM | #2 |
Re: A few random questions (that I didn't find answer to in the FAQs)
I asked the same question about the rear bumper. Here's my thread. Scroll down to the bottom. The photo's really helped me.
http://67-72chevytrucks.com/vboard/s...d.php?t=632243
It only has original paint once |
08-15-2014, 06:58 PM | #3 | |
08-15-2014, 08:41 PM | #4 |
The stepside and fleetside brackets look close but the stepside brackets (outers) won't reach the bumper on a fleetside. I learned that the hard way when someone gave me some brackets. Had classic next day me some brackets, to the hotel at a car show, and installed them in the parking lot. Once you see how they go, not that bad.
Can't help you with the thrift air, because i'm balling big with the deluxe heater ;-) There are wiring diagrams online on this site and all over, just keep looking. Google image search is amazing, hope this helps.
Project "i'm just going to clean up the interior and the engine bay": http://67-72chevytrucks.com/vboard/s...d.php?t=550931 |
08-15-2014, 09:06 PM | #5 |
looks like someone cut too much off the rear frame for some reason cuz those holes left dont look right and its way too close the the left springs
08-15-2014, 10:00 PM | #6 |
But Found Her 25yrs Later!
I've been digging through the forums to try and find an answer to your switch question.
I did find this cool thread; http://67-72chevytrucks.com/vboard/s...=heater+switch
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 |
08-16-2014, 12:42 AM | #7 |
Hey Jimal, I think you're missing your mounts for the rear sill. I'm 99.9 percent certain that Chevy/GMC never offered the rear "sport" bumper on the short bed K model pickups. The 4x4 Suburbans had a frame extension. The two wheel drive brackets won't fit. You'll have to fab some brackets if you want the "sport" bumper. You'll also need to fab some brackets to mount the rear sill of your bed.
08-16-2014, 02:10 AM | #8 |
Wow, I have never seen rear sill tabs on the frame like that before. Is your truck a 60-62 by chance? The older 2wd frames were wider and thus so were the mounting positions on the bed rails. But maybe all the 4wd frames were narrower like the later model 2wd frames.
When I put a 62 bed onto my 66 k10 instead of replacing the rear sill I just drilled out the spot welds on sill mounts and tack welded them into the narrower position to sit directly on the frame rail, like thr 63-66 pickups.
Jason M. @argonaut62 1972 K5 Blazer CST, Turquoise 1966 K20 Short Fleet Pickup, Big Ugly 1964 C10 Short Fleet, Gertrude 2001 Porsche 911 Carrera 1996 Ford Bronco XLT 1980 Jeep Wagoneer 2008 Honda CBR1000RR 2005 Honda RC51 1981 Honda CB750C No dis-assemble Johnny Five! No dis-assemble! |
08-16-2014, 09:51 AM | #9 | ||
08-16-2014, 09:54 AM | #10 | |
08-16-2014, 10:53 AM | #11 | |
08-16-2014, 11:46 AM | #12 | |
08-16-2014, 12:13 PM | #13 |
my 61 has the tab's for the rear sill. the early trucks used the 2wd sill from the x frame thus the brackets.
1961 chevy K10 my build is------------61K10 build |
08-30-2017, 11:23 AM | #14 | |
