Air noise from vent window seals?
I put those Precision brand windows seals on my truck a while back. Think we had another thread talking about them at some point. But what I'm focusing on today, is the fact that there is a ton of wind noise I need to get rid of.
You can hear it at about 35mph, but at 65mph its unbearable. Now I did seal it up pretty good with black silicon, and that took the noise level down a good bit. Bit its still too loud for my taste. You know how old vehicles can be. But I think it can be solved because it seems to only be coming from the top area of those vent windows. But it is both of them. Are there any tips or tricks that anyone might suggest, to get rid of wind noise? I guess I could go back at it with the silicon, but I was hoping there was more I could do. Any suggestions? Oh and I siliconed those vent windows shut, by the way. I never use those anyway. |
Re: Air noise from vent window seals?
It is possible you got the wrong ones. There is a 1 pc and 2 pc design.
No I got the one piece, which is what came off the truck
My passenger side wing vent does the same thing, and I'm not ready to tackle the seal replacement chore, so for now I just leave it cracked open a tad so it stops whistling.
"Off the grid and on the seven day weekend plan" "One person cannot know everything, but between all of us, there isn't much we don't know." |
#5 | |
Put a piece of cardboard behind the lock to make it close tighter.
Is the vent window sealed in the door? Seems to me if you siliconed the glass, the noise isn't coming from there. Maybe around the outside of the window, or the door directly above the vent. This is on the assumption that the door fits properly and doesn't stick out like a side scoop into the wind.
'86 C-30 dually, 454/tbh400 '73 K-20 350/350/205 (sold ![]() I'm kinda like duct tape- no real purpose, but handy to have around. |
#8 | |
I've heard some people say that its just part of having an old truck, but there is a way to fix it because you know GM didn't sell them that way when they were new |
At the body shop.
A dime and a nickel in the latch...
" That didnt make it any newer " " Dont antique the equipment " |
Like mentioned, shim the latch. GM didn't sell them that loose or expect you to still be driving these. Latch on my '86 is sloppy, but so are the window seals. With an open window I don't notice the noise.
Picked up a door out of a garage being torn down, vent window siliconed, soo not a new problem
I just replaced mine, and they still make a little noise too.
#12 | |
I played around with mine and it helped a ton.
" Never look up a dead dogs butt." ![]() |
#13 |
#14 | |
But - yes - wind noise was a hearty perennial problem. We would energize a team and they'd do a bunch of testing and design changes or process changes and things would get better - for a little while - and then worse again. When we would fluff and puff a truck for an executive to drive you knew ahead of time what you were going to have to fix: a) Wind noise b) Balance and vector tire/wheel assemblies c) Rear axle whine d) Flatten the paint e) anything wrong that was specific to that particular truck K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
#15 |
A lot of people are saying to make the doors close harder by one means or another. Putting money or cardboard in the latch. But I've already siliconed them shut, I'm afraid. So that probably won't have much of an effect.
#16 |
![]() Join Date: Nov 2013
How well do your doors line up? A lot of noise coming through on my truck went away when I replaced the hinges and closed a lot of gaps. It isnt completely quiet, but a lot of the noise that I blamed the vent windows for came around the doors and through the door panels from underneath when they were sagging.
1967 CHEVELLE MALIBU 427/700R4 1971 CHEYENNE 10 350/350 1983 GMC K3500 454/400/205 1987 R10 TBI 350/700R4 2014 CRUZE 2.0 TURBO DIESEL |
#17 | |
Here is a reply I got from the autobody forums, I thought it might help some other people here:
