Old 08-15-2014, 07:41 PM   #1
Handmedown
Handmedown's Avatar
Hood hinges
Where are you guys getting the cheapest hood hinges. I have only been finding them for 80 or 90 plus shipping each.
Handmedown is offline   Reply With Quote
Old 08-15-2014, 07:51 PM   #2
69chevytrucker
69chevytrucker's Avatar
Re: Hood hinges
4143-210-67L and r are only 63 bucks from crosscanada parts which means down in the states should be cheaper i think they get there parts from Kansas try the part number see what you get down there
69chevytrucker is offline   Reply With Quote
Old 08-15-2014, 07:54 PM   #3
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Re: Hood hinges
Salvage yard. Cheap. Then take to a plater for phosphate coating (Parkerizing) will look and function smoothy as new provided you picked a good set. Can have other items phosphate coated at same time like door strikers, hood latches, pulleys, bolts.
Old 08-16-2014, 12:48 AM   #4
russgoodman
russgoodman's Avatar
Re: Hood hinges
The right one is still available through GM. I got one 2 weeks ago for $61 out the door with a shop discount.
1969 Chevy C10 SWB Fleet - Build thread > http://67-72chevytrucks.com/vboard/s...d.php?t=593554
2008 GMC Sierra Denali - 6.2L AWD - my daily
2011 Ford Flex Limited - Ecoboost AWD - wife's daily
1987 Buick Regal Turbo T - 63K miles - Strip/Street car
1965 Ford Mustang Coupe - 289, c4, 53K miles
russgoodman is offline   Reply With Quote
Old 08-16-2014, 09:36 AM   #5
Bad Jackson
Re: Hood hinges
Right... but not Left??? That seems odd.
I work with tools.
Bad Jackson is offline   Reply With Quote
Old 08-16-2014, 09:40 AM   #6
88fordf150
88fordf150's Avatar
Re: Hood hinges
Parts Geek for $34.73. But there out of stock.
Brad handshoe
88fordf150 is offline   Reply With Quote
Old 08-16-2014, 09:48 AM   #7
88fordf150
88fordf150's Avatar
Re: Hood hinges
Summit Racing has them for $39.97.
Brad handshoe
Old 08-16-2014, 10:11 AM   #8
sixtyeightC10
Re: Hood hinges
I wouldn't necessarily go cheap as that they may be the cheap chinese reproduction knock-off parts that I wouldn't trust on my truck. If at all possible, pony up the few extra bucks and get something that you know will last you. I went cheap on my heater controls and my headlight relay conversion on my '68, and I've been regretting those ever since.
I went cheap on stamped steel engine covers (valve covers, timing cover, oil pan) on another project and I could never get them to seal right. Do yourself (and your truck) a favor, don't go cheap. I understand that money can be tight, but just don't rush out and buy the first part that you can afford. Save up a little more for the better quality parts. Cut out the morning coffee or the pepsi every day until you have the money for the better parts.
Just my two-cents worth.
1968 C10, 327 large journal crank, TH400 trans, 12 bolt 3.73 geared rear axle, and rear leaf springs. HEI, Delco 10SI, and brake booster upgrades.
Formerly known as mtndewmaniac66.
sixtyeightC10 is offline   Reply With Quote
Old 08-16-2014, 11:24 AM   #9
flashed
Re: Hood hinges
Find used ones and have them rebuilt ,a guy on Team Chevelle does them .
flashed is offline   Reply With Quote
