08-15-2014, 11:30 PM | #1 |
70 Jimmy, Hill Climbing, and Fuel Pickup
I have recently replaced the fuel tank in my 70 Jimmy 4x4 and eventually I want to do some hill climbing in it. However, today I was watching some hill climbing videos and got to wondering, what's to keep the fuel from draining away from the old, non-fuel injected sending unit (or even a fuel injected one for that matter)? While changing my tank, I noticed that the sending unit doesn't have a way to keep gasoline over it for constant pickup. Is there some kind of mod you're supposed to do? Or just run and hope for the best? I don't imagine that "back in the day", or even nowadays, the average off-roader made fuel tank mods to keep that from happening.
Thanks for any info y'all can give me!
My toys: 1971 GMC Jimmy 2008 Hummer H3 Adventure 2003 HD Road King Last edited by vancelot69; 08-15-2014 at 11:59 PM. Reason: I have a 70 Jimmy, not a 67. der |
08-17-2014, 03:16 AM | #2 |
Re: 70 Jimmy, Hill Climbing, and Fuel Pickup
You could baffle the tank http://www.summitracing.com/parts/aei-18650/overview/ but the other problems can be the carb floats can make it flood out and or lean out on a steep hill.Or off camber the oil pump can suck up air giving you low oil pressure.
08-17-2014, 01:14 PM | #3 |
Don't hill climb on a low tank. A fuel regulator helps with float issues due to angles and bouncing. EFI operates on a closed pressurized system,so no worries.
You can't lean a truck hard enough (without rolling) for oil to cavitate from the sump pickup. On my '71 Blazer that I wheeled hard back in the day I installed a 6qt oil pan,2qt filter,and hi-volume oil pulp just because I wanted to do anything that enhanced it's off road performance.
