08-16-2014, 12:43 PM | #1 |
Edelbrock 4bbl gas pedal link?
What are you guys using for gas pedal linkage on Edelbrock 4bbls? I want to use my stock V8 linkage, but its not plug and play. I had a stock linkage setup on my truck years ago, but must have lost some parts.
08-16-2014, 01:10 PM | #2 |
Re: Edelbrock 4bbl gas pedal link?
I used the stock threaded arm and barrel nut. The fit was loose so I used a small rubber grommet between the link and quick clip.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats http://www.cardomain.com/ride/332579...t-c-k-pick-up/ http://67-72chevytrucks.com/vboard/s...d.php?t=560081 |
08-16-2014, 09:19 PM | #3 |
Anyone have a close up pic of their setup? My throw seems too long...
08-16-2014, 10:23 PM | #4 |
I tried all day to get the pictures to download all day. It is a Holley but same set up was on the Edelbrock. First shot is the firewall side, 2nd is the rubber grommet and quick clip on the backside of linkage, last is side view.
08-16-2014, 10:34 PM | #5 |
ok that's interesting, I noticed your crank arm is pretty close to the intake manifold. I thought it needed to be higher. Maybe I will be ok then, thanks for the pics
08-17-2014, 03:45 PM | #6 |
I found the factory linkage too short for an Edelbrock 1405 on a 1" phenolic spacer. I used a piece of 1/4-28 all thread and Mr. Gasket ball/socket ends with jam nuts. Part #3811G on Summit.
EZ to set up and the ball ends pop-off if you need to disconnect linkage. I used heat shrink tubing over the threaded rod to hide the threads and keep it from discoloring. Looks slick and works great. Infinitely adjustable too. |
08-17-2014, 06:54 PM | #7 |
Who Me?
Mine is the same as LVPhotos. Works just fine.
Steve 1997 Tahoe LT 4D 2WD (DD) 2001 Blazer 4D 2WD 1961 Apache 10 (sold) 1965 C10 Stepper (sold) |
08-17-2014, 09:23 PM | #8 |
Thanks for the response guys. I decided to make a proper length rod as the one I have is too long for some reason. How long is the stock V8 rod? Total overall length? I think mine is like 11"
08-17-2014, 10:10 PM | #9 |
12" total. Elbow to thread end. About 11.5" center to center. Stock 283 link.
08-18-2014, 09:52 AM | #10 |
I bought a round stock 1/4" with Mr. Gasket linkage bushings. Works great with the v-8 throttle lever...
CURRENT & PAST CHEVY TRUCKS 60 C-10 Apache short step side 62 C-10 short step side 66 GMC Long bed fleet side 305 V-6 77 C-20 Custom Deluxe (Blue Goose) |
08-18-2014, 10:58 AM | #11 |
Doobiebro, that looks sweet. I decided to make my own setup, should be done today, ill post some pics later.
08-18-2014, 11:06 AM | #12 |
Heres a new brass pivot I made. Going to make a stainless arm later.
08-18-2014, 11:13 AM | #13 |
08-18-2014, 12:45 PM | #14 |
Got everything I needed for my 700R4 trans install from Bowtie Overdrives 5yrs ago and still running like a champ! The bottom carb bracket is made for an Edelbrock carb. Check them out..
08-18-2014, 03:43 PM | #15 |
08-18-2014, 04:35 PM | #16 |
Ok so heres the finished product. Just like stock just shorter.
