Truckin' Krazy
![]() Join Date: May 2000
1972 C30 Longhorn for parts
Parting out this long horn.
Already sold are: the fender emblems, bed,steering column. This whole chassis will be for sale either whole or in pieces, 350 engine, good ac cab, auto, HO52 rear This is also getting parted out locally. Auxiliary factory fuel tank parts available Bare AC Cab with out doors $700 with title SOLD Rear slider $40 + shipping Auxiliary battery tray, wiring & washer bottle bracket $130 shipped. SOLD Front fenders in good shape $125 ea 350 Engine $200 Headers $90 Complete rolling Chassis $400 Anything else ask & I'll price Thanks, Tom
Dealer for: American Auto Wire Precision weatherstripping Dakota Digital Trim parts Carpets Truck World seat covers & Many others Chevy Parts locator in Mesa AZ! Last edited by t korinek; 09-03-2014 at 01:04 AM. Reason: more parts |
Truckin' Krazy
Re: 1972 C30 Longhorn for parts
Something I've never noticed before is the Carrier bearing is mounted to its own cross member, looks pretty heavy duty, maybe a 1 ton thing.
Dealer for: American Auto Wire Precision weatherstripping Dakota Digital Trim parts Carpets Truck World seat covers & Many others Chevy Parts locator in Mesa AZ! |
Carpe manana
![]() ![]() Join Date: Dec 2010
Is the lever for the floor mounted aux tank selector valve there and intact?
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 ![]() |
Truckin' Krazy
Pete I'll check that, I did already pull the fill tube, cover, gas tank & sending unit & was able to save 2 of the long bolts with the special threaded nuts, all of which is for sale.
#5 | |
Cluster King
![]() Join Date: Nov 2012
That is different Tom. I have never seen a carrier bearing mounted above the cross member either. Now I want to look at my 72 1/2 ton with factory leafs and see what the set up is. Good luck with the sales, Tom
Contact me on all of your gauge cluster needs. I specialize in restoration, repair and parts sales for 67-72 Chevy and GMC trucks. email me at tbonegarris@yahoo.com I am also a dealer for Counterpart for gauge cluster parts only. Also see my facebook page, CG&C |
![]() Join Date: Apr 2010
How much for the tilt?
![]() Join Date: Jul 2013
Interested in the rear slider. Could I get some better pictures. How is the latch and felt. Was it on the option list as factory oem or it aftermarket?
Truckin' Krazy
Hey tbone, I'll bet your 1/2 ton doesn't have this set up!
I'll have to get more pics, slider was on the spid Thanks Tilt was a good one, unfortunately gone already, I didn't get it either ![]()
Carpe manana
I'd be interested in the aux tank send unit if you'd sell apart from the rest. If so, any idea if it works? Thanks Tom
Truckin' Krazy
I'll test that sending unit, if I don't get a few bites on the complete set up after a few days I'll sell it separately.
Carpe manana
Appreciate the help Tom thanks. LMK on the lever when poss. Pete
#13 |
Interested in the bottom seat foam if it is driver quality, also wire harness from cab to rear crossmember. Ship to 78602. Thanks!
1971 Bone Stock C10 project "Jake" 1997 Sierra SLT factory short bed "Silver Bullet" |
#14 |
![]() Join Date: Jun 2005
Good Morning Tom! Interested in the front sway bar and brackets (SIZE?) if you part out the frame. LMK Thanks, Dan
#15 |
If you part out the frame I need the rear shock mounts.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
#16 |
![]() Join Date: May 2012
Hey tom, do you still have the heater/ac control in the dash?
mike
my build thread http://67-72chevytrucks.com/vboard/s...d.php?t=522167 vietnam vet 67-68 |
#17 |
I want the complete rolling chassis just need to find it a ride to Michigan how much for the chassis?
#18 |
Carpe manana
It's already got a Michigan sticker for you
#19 |
![]() Join Date: Jan 2007
Shipping quote to 15024 on the cab please
Thanks |
#20 |
I am interested int he cab on the chassis as well. is there any one out there that can haul it to MI.
#21 |
Truckin' Krazy
pics of slider
Works ok, latch is good, says passport on it, there is scuffing on the lower outside bottom & the weatherstripping probably needs to be replaced in it because the sliders move around when you slide them side to side.
#22 |
Truckin' Krazy
Here's some pics of the cab
The cab has a little more rust than anticipated, so I have adjusted the price to $500 for the bare cab with title. There is no rust in the roof or drip rail, cab corners look good, cab supports look good. Some rust in the lower door pillars especially the passenger side, where the lower door hinge was welded on There is also the normal lower kick panel rust about 1/4 to 1/2" up from floor. There is rust in the outer rockers. There is some bubbled rust under the floor mat, that will leave pits after blasting, but is not rusted through & there is also a rust spot on the engine side of the cowl on the driver side that is rusted through. The radio hole has been cut to a square. None of this rust is major or out of the ordinary, but want to disclose the shape of the cab so there are no surprises. I can strap to a pallet & we have a tractor to load it or have room for an auto transport to pick up the rolling chassis, you will have to research & arrange your shipping on the cab or chassis, (you ship) is a good place to start. Critterman Price of rolling Chassis is $425 with bare cab $800 67-72 trucks has passed on the cab natec/10 you are up on the cab. w314speed, sway bar is the normal 3/4 ton size 1 1/8" mike 1971 the ac control is gone , but I have another $60 shipped without mount bracket. 72 mario I should have a set of the rear shock mounts already off another truck $40 for the pair shipped. jake, I'll check the cab to rear harness, foam is not good enough to ship.
Dealer for: American Auto Wire Precision weatherstripping Dakota Digital Trim parts Carpets Truck World seat covers & Many others Chevy Parts locator in Mesa AZ! Last edited by t korinek; 08-18-2014 at 01:53 AM. |
#23 |
Truckin' Krazy
Rust in floor looks worse in pics, sorry, I didnt get too many good shots, I just focused on the areas I thought that needed work.
#24 |
Thanks for the pictures and the honest description. I could overcome everything but the major scuffing on the bottom right of the outer frame. I will pass on the slider.
#25 | |
