Old 08-16-2014, 09:13 PM   #1
Mv7fd
how much will it really pull
how much will a 79 k20 with a 4 speed and 4.10 gears and a 350 really pull. i know what they are rated for but I've seen people pull some pretty big stuff. would it pull an 18 foot car trailer with a car on it
Mv7fd is offline   Reply With Quote
Old 08-16-2014, 09:22 PM   #2
casper71
Re: how much will it really pull
That combo will pull an 18 foot car trailer loaded with no problem. I had a 292 in my truck and towed everything I could fit on trailer. easily will tow 8k.
1972 3/4 ton 402/400
1971 k20 lwb 8.1.4l80.np205 w/37" tires and 6"lift
casper71 is offline   Reply With Quote
Old 08-16-2014, 09:37 PM   #3
79Betty
79Betty's Avatar
Yea it'll tow it bla bla bla. Yea mine pulled such and such's big 1 ton yadaa yadaa. Pulling is the easy part... Just make sure you can stop and give yourself plenty of room. I know, kinda sounding like an ass here and sorry if i offend you. Just better safe than sorry... Running halfway over the ricer in front of you with a 1 ton ford on a car hauler in your truck is some scary $hit.
When in doubt, throttle it out!
1974 Chevrolet Custom K20
2005 Ford Ranger Edge
1985 Chevrolet Custom Deluxe C10
79Betty is offline   Reply With Quote
Old 08-16-2014, 09:38 PM   #4
Mv7fd
no offended at all. i guess you can really pull anything as long as you can stop
Old 08-16-2014, 10:21 PM   #5
xole
xole's Avatar
+1 issue is stopping, not pulling.
'86 Chevy K10 SWB Custom Deluxe 4x4
'94 Chevy Corvette
'07 Ford Mustang
'08 Lexus LS 460
xole is offline   Reply With Quote
Old 08-17-2014, 03:10 AM   #6
andrewmp6
It just depends how much the car and the trailer weight if you should pull it or not.As far as being over loaded its a nice fine if you get caught.
andrewmp6 is offline   Reply With Quote
Old 08-17-2014, 11:35 AM   #7
cadillac_al
A car and trailer is a pretty light duty load. Stations wagons used to pull that easy enough. A K20 with bigger brakes will have no problem at all.
76 Chevy K20
76 GMC K15
77 Chevy C10
77 Chevy K10
cadillac_al is offline   Reply With Quote
Old 08-17-2014, 12:48 PM   #8
xole
xole's Avatar
The bottom line is there are a lot of different variables including...
1) Ratings of tow vehicle
2) Hitch type and rating (don't forget goose neck)
3) Trailer type (single/tandem axle)
4) Tongue weight
5) Trailer brakes
6) Weight of load
7) Weather, terrain and altitude (higher the less engine power you have)
Every situation is different.
Personally, if it where me I would want a tandem axle trailer with brakes which it sounds like you have covered.
'94 Chevy Corvette
'07 Ford Mustang
'08 Lexus LS 460
Old 08-17-2014, 01:25 PM   #9
Old Truck Man
Old Truck Man's Avatar
One thing Not mentioned is the drivers experience. I used to drive semi truck. Back in my late thirties & early forties I was a heavy hauler. the truck was engineered for a 80,000 pound pay load. Yet I commonly hauled loads grossing 180,000. The truck could pll it Ok. Going down steep grades and stopping was the tricky part. My expierence allowed me to do the job without incident. It was legal because we purchased overweight permits. Even today I pull trailers behind my 66GMC 1/2 ton. It has a granny four speed and will pull ok. The drum brakes and single master cyl and the fact that my trailer brakes are very poor makes it unsafe for the novice. I never have problems because I Know How. there isn't a weight limit on 1/2 or 3/4 ton trucks in Arkansas. As long as you don't exceed the weight limit rating on the sidewall of your tires.
Old Truck Man is offline   Reply With Quote
Old 08-17-2014, 01:29 PM   #10
Keith Seymore
Keith Seymore's Avatar
No problem.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 08-17-2014, 01:30 PM   #11
Keith Seymore
4) Tongue weight
5) Trailer brakes
6) Weight of load
Those are considered but the final check is launchability on a 16% grade.
If the truck cannot launch at GCVW then the rating is knocked down until that configuration passes the specific test.
That weeds out a lot of combinations that would have been rated higher.
K
1979-1986
1986 - 2019
Old 08-18-2014, 11:58 AM   #12
ETKTRYD
ETKTRYD's Avatar
X2.... STOPPING is the issue in my book !!!!!!!!!
ETKTRYD is offline   Reply With Quote
Old 08-19-2014, 08:26 AM   #13
86c20
86c20's Avatar
when i was dumb and thought i could do anything i would pull 20k plus with my truck starting is ez mantining ez it was the stoping. now years later and a class a cdl i look back and say what a fing dumbass i was. what if some kid ran out? there was no stoping that truck and trailer at all. my c20 with 4 sp llow will pull a bobcat trailer and cat no problem. little more and she is not all that happy. get a good contorler and make sure the brakes are good on the trailer. also. balence the load all on the tail no good all on the noise no good. with mine i found just a tuch forward on the trailer and the ride was good the brakes where good and no wondering down the road
1986 c20 "the hillbilly" 350 sm465 3.42gears 21mpg at 70mph
1985 k30 "the ice cream truck from hell" no rust az truck
197-8??? c30 "ramp truck" 454
1978 monte carlo 350 350th with 2.73 gears. no rust. sc car
86c20 is offline   Reply With Quote
Old 08-19-2014, 08:36 AM   #14
Desert1957
Desert1957's Avatar
Excellent response..
Desert
Desert1957 is offline   Reply With Quote
