Old 08-17-2014, 09:24 AM   #1
Andy4639
Old member
Andy4639's Avatar
New Shroud...and other stuff
I stopped by a local metal fab shop a few weeks ago and asked if they could build me a shroud for the radiator in the 71. I have the electric fans with a little shroud made on them but it doesn't cover the whole radiator. He came out and measured it and made me a shroud for $20.00. It's 2" deep so I can trim it down if need be. It's 28.5" long to fit between the tanks and 18" tall.
I went to pick it up and asked him to look at making me a motor cover. I hope he has it ready this week some time.
Both are made out of aluminum.
Now I have to find time to install them!
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 08-17-2014, 03:48 PM   #2
kamikazekyle05
kamikazekyle05's Avatar
Re: New Shroud...and other stuff
That looks good!
kamikazekyle05 is offline   Reply With Quote
Old 08-17-2014, 04:33 PM   #3
Andy4639
Old member
Andy4639's Avatar
Wink Re: New Shroud...and other stuff
Originally Posted by kamikazekyle05 View Post
That looks good!
Thanks,
for the price he did it for it's beautiful!
Old 08-17-2014, 11:10 PM   #4
82ZZZR
good score on the cheap!
82ZZZR is offline   Reply With Quote
Old 08-19-2014, 08:03 PM   #5
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: New Shroud...and other stuff
Went by yesterday and spoke with him. Said to come back tomorrow and he would have it bent up.
Old 08-22-2014, 04:12 PM   #6
Andy4639
Old member
Andy4639's Avatar
Question Re: New Shroud...and other stuff
Well I picked up the engine cover and have the trim all done. Just have to decide if I want to have the front part welded on it are not.
What do you all think?
I'm wondering if it will make the engine run hotter also.
I'm going to have it painted the same Gun metal grey as the truck bottom.
Old 08-22-2014, 05:42 PM   #7
Houston Ben
Houston Ben's Avatar
Hi Andy, nice find! I would put the front part put on for strength and one on back as well. With mine I think if I didn't have the parts on it would be way too flimsy and vibrate.
Houston Ben is offline   Reply With Quote
Old 08-22-2014, 10:03 PM   #8
Andy4639
Old member
Andy4639's Avatar
Cool Re: New Shroud...and other stuff
Thanks,
The front will be put on for sure to strength. The back is fine. I have it bolted down on top and on both sides.
Old 08-23-2014, 08:16 AM   #9
faribran
Painting this red?
faribran is offline   Reply With Quote
Old 08-23-2014, 10:51 AM   #10
Andy4639
Old member
Andy4639's Avatar
Originally Posted by faribran View Post
Painting this red?
More than likely it will be Grey like the bottom of my truck but it may get 2 toned! I have some decals being made for it also. Haven't decided yet but it will get painted for sure. Going to see if he can louver it also on top to help with the heat.
Drove the truck this morning and it did fine. Temp was not even noticed being any different than before.
Old 08-25-2014, 06:04 PM   #11
Andy4639
Old member
Andy4639's Avatar
Talking Re: New Shroud...and other stuff
Took the cover back this morning to have the front weld on. $80.00 for it. He is going to make me a cover for the radiator now also.
If anyone is interested in this cover LMK. $100.00 + shipping to your door. You will have to trim it out to meet your engines needs but it easly done with snips. That's how I did mine. The front will be already trimed per mine but you may need to trim it more for you application.
Old 08-30-2014, 06:13 PM   #12
Houston Ben
Andy, what size bolts did you use to hold the cover in place? I bought M6-1.0 bolts but they seem just a hair big. The bolt I took out of the intake fit into M6-1.0 slot at the store so I thought the bolt would fit. They start to thread into the hole but get tight real quick, I haven't tried to torque on them a little to make them fit yet.
Old 08-30-2014, 07:03 PM   #13
Andy4639
Old member
Andy4639's Avatar
On the 2 top center bolts I used 2 of the 3 that held the plastic peice on the back of the intake. The black plastic in the picture I removed it and used the 2 center ones to mount. Sorry I have no idea what size they are.
The sides I used 4-20x1/4" bolts in the coil brackets with a spacer and lock nuts.
Old 09-06-2014, 08:59 PM   #14
Andy4639
Old member
Andy4639's Avatar
I picked this up today for $150.00 from a fellow Upstate SC GM truck club member.
Old 09-06-2014, 09:03 PM   #15
Houston Ben
Nice score
Old 09-07-2014, 01:38 PM   #16
Andy4639
Old member
Andy4639's Avatar
Nice score
Thanks, drove the truck to church this morning and noticed the AC didn't get cold. Pulled over to have a look and the back fitting on the compressor was leaking. Cut it off drove on. Came home and tried to tighten it. Nothing doing it's blowing out the fitting. I think the O-ring is gone.
Old 09-11-2014, 10:13 PM   #17
Andy4639
Old member
Andy4639's Avatar
I had to leave and come to the beach this week for a friends son. he got killed in a motor cycle accident. My daughter went by and picked up the engine cover for me today. Can't wait to see how it looks installed. Then take and have it painted.
Old 09-12-2014, 12:49 PM   #18
Andy4639
Old member
Andy4639's Avatar
Here is the cover. I will clean up the welds a little then polish it out and see how I like it. I will decide then if I will have it painted are not.
Old 09-13-2014, 12:34 AM   #19
BigDan3131
BigDan3131's Avatar
If you know anyone with a bead roller it would take out some of the flex or you can do it yourself. They sell one at Harbor Freight.
Custom Painter/Restoration Specialist
1965 GMC 3/4 Ton LB SOLD?
1964 Chevy El Camino in full restoration
1991 Chevy S10 288K+ miles 2nd Owner SOLD
2020 RAM 1500 Warlock
BigDan3131 is offline   Reply With Quote
Old 09-13-2014, 09:54 AM   #20
Andy4639
Old member
Andy4639's Avatar
Thanks,
I don't think it will need it though. It wasn't flappy at all it wasn't big enough and with the 4 attachment points it was pretty solid.
Old 09-13-2014, 10:43 PM   #21
Andy4639
Old member
Andy4639's Avatar
Well I know not many of you are interested in it but here it is any way. I got it installed and it looks pretty nice I think and it hides all the ugly truck intake for sure. I still have to get it painted though.
Old 09-13-2014, 10:49 PM   #22
Houston Ben
I like it, can't wait to see it painted!
Old 09-13-2014, 11:09 PM   #23
Andy4639
Old member
Andy4639's Avatar
Thanks man!
Yea me too! I got to find some one that can do air brushing on it. A friend of mine has some 6.0 Bowtie decals for it also. But I want a little more custom job on it though I think. Painting it will hide the weld some to I hope.
I got to get that new booster done and then pull the radiator out and get the shroud installed.
Old 09-13-2014, 11:50 PM   #24
bpatrol
looks good. its nice to be different
great job
bpatrol
bpatrol is offline   Reply With Quote
Old 09-14-2014, 09:18 AM   #25
Andy4639
Old member
Andy4639's Avatar
great job
bpatrol
Thanks man.
A friend of mine just told me on facebook he will paint it for me. He is a member of our truck club. COOL!
