belt routing
Anyone have a picture of a 250 l6 with p/s and ac to see how belts are routed.
I am a Referee of life.
Re: belt routing
Are you looking for the factory routing? In any case,the pulleys should line up with the accessory they drive.Most belts will run crank, water pump, and then whatever accessory.If you added PS and A/C than you need to look at what is there and see if you can get the pulleys to line up.There are at least 2 versions of the PS pump brackets and pulleys ,so the routing may be different on them.I've never had a chance to compare the two side by side.Sorry I don't have a pic of this.
BTW you will need enough pulley grooves to match each accessory.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
Re: belt routing
I have two grooves and added the air.
