Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > Heavy Haulers
Old 08-17-2014, 01:07 PM   #1
jumpsoffrock
20,800 rear spring nd 8,000lbs front spring. What does this mean for payload/GVWR?
My '67 C50 has two options: G56 : 20800-LB REAR SPRING
F92 : 8000-LB FRONT SPRING
What does this have to do with my trucks 19,500 GVWR? I just can't figure this out? And how can you have 8,000lbs springs on a 5,000lbs axle, which is what I have.
I don't understand how this play together. Anybody get it?
Thank you very much.
jumpsoffrock is offline   Reply With Quote
Old 08-17-2014, 03:29 PM   #2
C10 - C90 Bill
C10 - C90 Bill's Avatar
Re: 20,800 rear spring nd 8,000lbs front spring. What does this mean for payload/GVWR
I'm not real sure either, but my '67 GMC 7500 had something a little strange on it. The Tag read 9 Fronts and 22 Rears which should have been a GVW of 31,000, but the GVW Rating on it was stamped "27,500" ??
'60-'72 Chev/GMC Fan
GMC 9500 Fan
Detroit Diesel Fan
C10 - C90 Bill is offline   Reply With Quote
Old 08-17-2014, 03:35 PM   #3
C10 - C90 Bill
"What does this mean for payload/GVWR"?
Even though your truck evidently has Heavier Springs on it, the law will go by what the Tag states. If you want a heavier allowance, you would most likely need it to be certified first.
GMC 9500 Fan
Detroit Diesel Fan
Old 08-17-2014, 07:16 PM   #4
mrolds88
GVWR will always go by the lowest rating of the components in the system. 8k springs with a 5k axle will rate out at 5k. Same goes for the rear. If it were done the opposite way, (as they would look at it) it would 1. Open up the manufacturer to legal liability, and 2. create a safety issue. In that order.
72 GMC C2500 402/Th400 first truck (still have)
77 GMC C3500 CC dually Sold
70 C50 dump truck "Rusty"
87 K10 Suburban Sold
93 K2500 xcab 6.5TD
96 GMC K2500 Suburban 6.5 TD
mrolds88 is offline   Reply With Quote
Old 08-17-2014, 10:02 PM   #5
jumpsoffrock
I'm sorry, but that all sounds extremely suspicious on the part of GM. Offer the availability of heavier duty individual parts to increase trucks workload, but allow customers to leave with out other parts that render the upgrades physically and legally pointless?
hmmmm, I'm not meaning that you guys are wrong......but something smells extremely fishy here.
At least I'm not the only person unclear on the topic.
