Old 08-17-2014, 03:50 PM   #1
AcampoDave
AcampoDave's Avatar
vintage air unsure fit
The lines on my evaporator don't seem to be in a suitable configuration for the firewall template. The small line is the one in question. It barely passes thru the bulkhead while the others protrude sufficiently enough to make the connections. Any ideas or suggestions?
AcampoDave is offline   Reply With Quote
Old 08-17-2014, 04:25 PM   #2
vin63
It's Better With Nitro
vin63's Avatar
Re: vintage air unsure fit
After I tightened all of the lines in the correct position, I did have to bend mine slightly to match the pattern on the bulkhead plate and to extend far enough.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 08-17-2014, 04:30 PM   #3
AcampoDave
AcampoDave's Avatar
Here it is installed. Does that small line seem right then? Thanks
Old 08-17-2014, 08:13 PM   #4
MadRatt
MadRatt's Avatar
looks fine, I had to bend and manipulate mine to pass properly thru the firewall template. The small silver line you see running up the inner fender well is the line that will attach to the line your talking about. you have room to maneuver.
If you ain't living life on the Edge....
Your taking up entirely to much space!!!!
My 64 Stepper Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=586792
MadRatt is offline   Reply With Quote
Old 08-17-2014, 11:07 PM   #5
AcampoDave
AcampoDave's Avatar
Yep, thanks guys. There was enough to get a hold of. Seems the Vintage Air instructions are somewhat vague.
Old 08-17-2014, 11:16 PM   #6
Ozzy2013
Ozzy2013's Avatar
Other than that hoe do you like the vintage air and which one did you go with?Thanks Oz
Ozzy2013 is offline   Reply With Quote
Old 08-18-2014, 01:14 AM   #7
AcampoDave
AcampoDave's Avatar
So far so good I guess. It's still not finished yet, but the quality seems good. I went with the "sure fit kit" the components are packed in component packs, i.e. the condenser, the evaporator, the brackets, etc. Each component pack has its own instructions which are mainly an exploded diagram with a brief set of steps, (reminded me a little of carb rebuild instructions) it is however quite do-able. Even by myself I make steady progress. You need to scource your own pulleys, heater hoses, and belts but pretty much everythng else comes packed in the boxes.
Old 08-18-2014, 01:45 AM   #8
Ozzy2013
Ozzy2013's Avatar
Thanks im looking at the gen 4 kit they sell just trying to convince myself to pull the trigger on 1300.oo ha ha
Old 08-18-2014, 10:25 AM   #9
AcampoDave
AcampoDave's Avatar
13k +tax, shipping, the parts I mentioned, the cost of getting it charged up...13 becomes 16 or more really quick.
Old 08-18-2014, 10:29 AM   #10
cab_01
cab_01's Avatar
If you get it from Summit it is free shipping. That is where I got mine.
cab_01 is offline   Reply With Quote
Old 08-18-2014, 08:51 PM   #11
Ozzy2013
Ozzy2013's Avatar
Thanks every bit counts!
Old 08-19-2014, 12:30 AM   #12
66 C10 383
You could also just get the Evaporator Kit from Summit for 780.00 with free shipping and then get the compressor, condenser, hoses, etc later as money allows ...
That's the way I'm doing mine ...
Doug
Old Build Thread - 383/T56
http://www.67-72chevytrucks.com/vboa...d.php?t=540838
Updated Build Thread - Modern Relic - 66 C10 536 Dark Aqua
5.3/4L60E - BTR Stage IV Truck Cam - Vintage Air - Dakota Digital
http://67-72chevytrucks.com/vboard/s...d.php?t=778784
66 C10 383 is offline   Reply With Quote
