Old 08-17-2014, 06:17 PM   #1
Terry Gartner
Fuel Sending Unit/Ammeter
Good Evening,
I have a 62 pick-up that had VDO gauges throughout. I like the factor look so I went back to the original gauges. My fuel gauge now is not working. I grounded the line to the gauge and got empty, removed the ground and it pegged to the right, so I guess he gauge is working properly. I can only guess that who ever installed the VDO gauge that it needed a different sender; or am I wrong. If I need to replace the sending unit, is there a specific resistance for this model year or is the 60 - 66 all the same?
As it relates to my ammeter I'm not exactly sure where I should hook it up. I've replaced the dash harness (using a new harness for 64 and turn signal switch - 64 as well); but the engine harness is a disaster and I expect I'll need to run a separate line. If that's the case where should I attach it?
Thanks for the help, sorry I don't get on here enough - retiring soon so I should do better!
1962 Chevy C10
1964 Pontiac GTO
1970 Pontiac GTO
1972 Pontiac GTO
Terry Gartner is offline   Reply With Quote
