Rear end ID
The truck I bought came with this extra rear end. I'm not familiar enough to ID, so hopefully someone out there knows by looking.
Here's what I have identified so far: 3.42 gears (based on GM 1235128 12 41 10 86) stamped on ring gear Is this an 8.2 or 8.5 10 bolt? Is it a locker/limited slip/open? Is it worth using over what I can only assume is a stock rear end (has discs on it already) Here are some pictures of the gears (click to enlarge) ![]() ![]() And what are these pieces that were loose in the housing? ![]() Thanks for any assistance. |
![]() Join Date: Sep 2005
Re: Rear end ID
looks like posi and those c clips hold the axle shafts in i woukd not run it till you check that the axles havec clips holding them in
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
Re: Rear end ID
Excellent. Thanks for the ID and move. I'll check the shafts to see if they are being held in. I'm a ways off running it, just working out what I've got myself in to.
60-66 Nut
![]() ![]() Join Date: Mar 2007
Re: Rear end ID
That does appear to be a 8.5" 10 bolt, and it has a gov lock, commonly known as a gov bomb. That won't stand up to much abuse.
#5 | |
Re: Rear end ID
I haven't opened up the differential that's already on the truck, so maybe it's a better setup. Really, I just got this one included because it has the discs on it already. I think I don't think I paid too much. |
60-66 Nut
Re: Rear end ID
Are they aftermarket discs or factory discs?
Re: Rear end ID
60-66 Nut
Re: Rear end ID
Just because they are GM calipers doesn't mean it is a factory disc brake assembly. Three of my rear disc brake conversion brackets use GM calipers. A few pick would help ID the brakes and likely a better idea on the differential.
#9 | |
Re: Rear end ID
I did look up the part number off the differential housing, but forgot what it said it was from.
In the garage: The project - 1968 C10 Short box The hauler - 1994 K1500 Silverado Z71 - Sold 2015 Colorado Z71 |
Re: Rear end ID
Eh, decided to go snap some now.
Click to enlarge: ![]() ![]() ![]() ![]() This one is upside down, didn't realize it until now. Part number 14055251 ![]() ![]()
Re: Rear end ID
Well, looks like the rear end already on it may have more potential. It is a 12 bolt housing. I haven't opened it up yet so no clue what is inside.
Planning on taking the bed off this weekend, so I will try and get at it at that point. Any chance the discs will bolt up to it?
60-66 Nut
Re: Rear end ID
Someone has converted that differential to discs, using the backing plate off of a K10 front differential and what appears to be '76-'78 Eldorado calipers. Not sure just what the rotors are, but it appears another wheel stud pattern has been drilled. I'm not sure just what you would have to do to bolt those up to your 12 bolt. Those backing plates have been modified once already. You might have to weld up some holes. Yes a truck 12 bolt is a better differential than the one you have with the discs on it.
I wouldn't get rid of those calipers.
#13 |
Re: Rear end ID
Well, I'm a little bummed that the "extra" axle isn't a direct bolt on like the guy said it was. But that's what I get for not doing my research before picking it up. I rolled it in to the price of the truck anyway, so it's not a huge loss if I can't use anything off it.
A quick glance at the 12 bolt shows a similar stud pattern for the axle, so I may get lucky. I'll know more this weekend. And I'll be posting pics of the gearing in the 12 bolt to get an ID on it too. Regardless, I'm guessing filling and then drilling new holes would be cheaper than a whole new kit, so I suppose I'm ahead at least a little. Thanks for your help on this Captainfab. I really appreciate the info.
#14 |
Re: Rear end ID
Well, sorry it took me so long to get back to this. Been busy tearing other stuff apart and haven't bothered to open the diff up until now.
Anyway, near as I can tell it's a 3.08 open diff in the 12 bolt. Both tires off the ground driver spins free passenger sticks. So, from my limited searching and knowledge I figure this one is more of a cruising gear. Anyone care to chime in? I'm interested to hear more opinions on this rear end. Anyone think I could sell both diffs I have and buy one that's much better without having to spend a fortune? ![]() ![]() ![]()
#15 |
![]() Join Date: Aug 2014
Re: Rear end ID
It look a little rusty in there kinda like some water got in it. I would rebuild that axle at least and probably put a eaton posi in and I like 4.10 gears but it depends on what you want to do with the truck.
#16 |
Re: Rear end ID
Well, I also just noticed this in the shot
![]() I'm not sure I'll go as low as a 4.10 (or is it high? Been a long time since I did ratios) It's my C10 I'm mostly interested in cruising around. Not going to be racing or anything, but I do like putting my foot down from time to time. I noticed the rust spots too, but I didn't notice any water when I emptied it. I think the seal on the back was bad. Looked like it had leaked on one side a bit. The diff fluid was thick. Never opened a diff before, though, so I'm not sure what to expect.
#17 |
60-66 Nut
Re: Rear end ID
It looks to me like a lot of the ring gear teeth are damaged. Apparently something came apart in there at one time. To answer your question,yes 3.08's are a good cruising gear. The size of your rear tires play a part in what is a good differential gear for your application.
#18 |
Re: Rear end ID
Based on the condition of the gear I'm probably going to be hunting down a replacement anyway.
Looks like it's time to research some factory gearing so I can know what to look for at the junk yards. I haven't been to a junk yard in years, and never since I've moved from Washington... This should be fun ![]() I'll continue research on my own, but if anyone has some suggestions for a good donor I'm open. Right now I have no idea what to look for on the surface, so it would be a lot of unnecessary tearing things apart at the yard to find what I need. Mostly stuff like what year did the 12 bolt come out, what years are the best to look for, etc. I may just buy new pieces, but my budget for that won't allow until much later. So I'd like to get something to hold me over.
In the garage: The project - 1968 C10 Short box The hauler - 1994 K1500 Silverado Z71 - Sold 2015 Colorado Z71 Last edited by Mindl3ss; 09-03-2014 at 09:52 AM. |
#19 |
60-66 Nut
Re: Rear end ID
The truck 12 bolt was used in the C10's from '63-'82 and the K5 and K10's from '63-'79. The '63 and '64 12 bolts have 17 spline axles which are not desireable. The passenger side axle tube has the original build code stamped into it, but who knows what has been done to the differential in X number of years. The only way to know for certain is to pull the cover and get the tooth count off of the ring gear. Myself, I like the 3.42 gears. You get decent off the line accelleration and the rpm's are a bit down from what a 3.73 would be. But if you aren't towing anything heavy and don't care so much about off the line performance, then the 3.07/308 gears would fit the bill.
#20 |
Re: Rear end ID
That's good to know. I would guess this one is from a mid-late 70's pickup, but I'll be counting teeth anyway just to be sure.
I think about the same for gear. My 1994 K1500 has the 3.73 in it, and it's a great rear end for that truck, but a bit low for the highway and cruising around town. It does get up and go okay, but at 65-70 it has trouble maintaining a steady RPM. I drove up to Seattle a few weeks back and tried using cruise control, but it would constantly bounce between gears while going up even a slight incline. This pickup won't be used for towing. It will be strictly a driver just to enjoy. I need to hang on to my K1500 for a while because it's my proven reliable pickup. After I get the '68 at least running I'm thinking about trading the K1500 for an older 1 ton if I can find one that doesn't need a whole lot of body work. My ideal situation would be an 86 K3500 or a pre-72 K30. I can't afford two projects, though.
#21 |
60-66 Nut
Re: Rear end ID
I forgot to mention that the '63-'70 12 bolts in the C10's will have the 6 lug wheel stud pattern. The '71-'82 will be 5 lug and also 1.5" wider. And of course the '71-'72 will mostly be for the trailing arms.
#22 | |
Re: Rear end ID
Seems I have quite the Frankenstein truck
#23 |
Re: Rear end ID
Well, I measured the studs on the 10-bolt rear end last night and found the guy was pretty much completely dishonest with me. It's a 5x4.75" pattern, which would be great for a car.
I saw a few of the gears and lockers on eBay sell for $259.99 plus shipping, which I figure isn't too bad. I should be able to get my money out of it if I split everything up. I'm kind of upset, but I'll get over it. I just need to clean it up a bit and sell it to make room in my garage. Had I been "smart" I would have measured it there in the shop when I was negotiating him throwing it in with the truck. That could have saved me some dough. It's just sad that people can't be more honest about stuff.
