Old 08-17-2014, 07:03 PM   #1
davepl
davepl's Avatar
How good is the AC in these trucks?
Reconnecting all of my AC stuff today, and although I've never had operational air, they did take their time to build a pretty nice system. I like how on max fan it runs straight 12V by relay, for example. And how it also supports fresh air, recirc, and so on. Other than a temp (like the Comfortron, which I assume wasn't an option) it really has everything.
Running it today it really moves some air, albeit room temperature for now.
I know the compressor is an older style, and R-134 may not work as well as R-12, but it's a small cab with a lot of airflow, so I'm curious how it compares to modern vehicles.
My Range Rover will push your hair back in all four seats while simultaneously pumping air through them, but I have reasonable expectations for a 40 year old truck, I think....
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 08-17-2014, 07:17 PM   #2
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: How good is the AC in these trucks?
Mine works well but on the lower settings I can barely feel the air movement. With some tweaking though it can run with the best of them. I have done away with the cowl vent. I sealed the flapper area off totally. I also made the passenger side vent inside the cab manual and it stays open all the time to recirc the cab air. I also installed a manual hot water valve to make sure no hot water runs through the heater and heats up the cab while the AC is running. I swaped everything over to 134a Freon years ago. The only thing now is if I could find a fan motor that would spin faster on the slower speeds.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 08-17-2014, 07:18 PM   #3
leddzepp
Moderator
leddzepp's Avatar
My factory AC with R 12 will freeze you out of the cab sitting still in 110 degree heat.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
leddzepp is offline   Reply With Quote
Old 08-17-2014, 07:21 PM   #4
davepl
davepl's Avatar
If you wanted more airflow at low settings you could change the heater fan resistor. Just measure it and replace with lower ohm resistors.
Only thing is they are a dead load - they have to dissipate everything as heat, which is why they're made of coils and directly in the airflow path, I assume. So it's not like you could stick a 1/4W resistor in there. But maybe there are different ones out there. Maybe Cadillac had different ones, who knows? But that'd be the best way to do it short of someone making a fan more efficient at that voltage.
Old 08-17-2014, 07:42 PM   #5
Andy4639
Old member
Andy4639's Avatar
Mine will keep the cab at 40* on a humid 90* and above day here in SC.
The lower speed settings are very weak in these year models no matter who's truck it is. On the lowest setting you will barely feel the air coming out of the drivers side ball vent.
I have thought about taking the motor and seeing if they can rewind it to get more RPM's out of it.
Old 08-17-2014, 08:33 PM   #6
FL71C10
Now we are hopping up blower motors? You know you are a gear head when...
71 Chevy C10 Shortbed Stepside. LT1 with
4l60E. Just got back from painter, in assembly now.
FL71C10 is offline   Reply With Quote
