Old 08-17-2014, 07:19 PM   #1
Paul Y
17" Steel Wheels?
Is anyone running 17" Steel wheels?
I really want to keep the 'stock' look of my truck but also want the stopping power provided by the big brake kits.
Apart from Wheel Vintiques series 62 is there another manufacturer that makes a stock wheel in the bigger size?
Would be interested to hear from others and. obviously, pictures!
Many thanks,
P.
Paul Y is offline   Reply With Quote
Old 08-17-2014, 10:04 PM   #2
Slow Build
Slow Build's Avatar
Re: 17" Steel Wheels?
Coker has a smoothie 17x7, 17x8 & 17x9.
Available in 5x5" or 6x5.5" lug pattern.
They also have some 18" steel wheels.
http://www.cokertire.com/searchbyatt...2&limit=16&p=5
Current Ride: 1964 C-10 Short Fleetside
Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe
Past GM Trucks:
1959 GMC short stepside
1968 GMC short stepside-4x4
1973 Chevy short stepside
1989 Chevy short fleetside-reg cab
1993 Chevy short fleetside-Xcab
2002 Chevy short fleetside-Xcab
Save the dinosaurs, use synthetic oil.
Slow Build is offline   Reply With Quote
Old 08-18-2014, 03:29 AM   #3
Paul Y
Thanks for that Rich,
Was looking more for a stock style wheel than a smoothie, all part of the sleeper image....
Looms like I will be forking out for the wheel vintinques then!!
P.
Old 08-18-2014, 04:06 AM   #4
andrewmp6
have you seen http://us-mags.com/plain-jane-u601-w...tm#prettyPhoto they have chevy center cap options.Or a 18 inch rim http://detroitsteelwheel.com/steel-wheels/
andrewmp6 is offline   Reply With Quote
Old 08-18-2014, 05:53 AM   #5
Paul Y
Oh look at all the pretty wheels.....
Seems to be a fault with the US Mags site but from what I did see I really like their Salt Flat look alike.
Problem is my budget wont stretch to them... Sausages...
Not a big fan of the smoothie look, can appreciate the style on certain vehicles but in my view looks a bit 'wrong' on a truck.
Thanks for taking the time to reply, appreciated.
P.
Old 08-19-2014, 08:34 PM   #6
theastronaut
theastronaut's Avatar
Circle Racing Wheels is making an 17-20" version of the stock wheels. It's their 108 series. Has the four slots and nubs for C10 caps, 10 1/8". They're around $2200 for 18's. I'm going to use 14.5" CTS-V brakes and they said that it would be close but they'd probably fit since it's a spun rim instead of cast.
http://www.circleracing.com/108oe.htm
theastronaut is offline   Reply With Quote
Old 08-19-2014, 11:53 PM   #7
spookylynx
spookylynx's Avatar
anybody use or know of these? they are 17" steels for a Chevy traverse...
I like he look but haven't found / figured out the bolt pattern
Amazon.com: 17" Chevy Traverse 6 Lug Steel... Amazon.com: 17" Chevy Traverse 6 Lug Steel...
spookylynx is offline   Reply With Quote
Old 08-20-2014, 12:05 AM   #8
rickywideglide
rickywideglide's Avatar
Amazon.com: 17" Chevy Traverse 6 Lug Steel Wheel Rim: Automotive
i believe thats a smaller bolt pattern, been looking awhile for 16 inch or bigger steel wheels for mine.have you seen fj cruiser steel wheels?very similar to those
rickywideglide is offline   Reply With Quote
Old 08-20-2014, 12:13 AM   #9
spookylynx
spookylynx's Avatar
just Googled those FJ wheels.. those are perfect! 6x5.5... that's the stock bolt pattern for the '65 correct?
http://www.wheelstiresandmore.com/To...FSsSMwodjxgA6A
Old 08-20-2014, 12:25 AM   #10
rickywideglide
yea same bolt pattern ,couple of guys run them on here, use search function on here for pics, only im not sure about backspacing one guy said they bolt up no problem ,other says needs spacers
Old 08-20-2014, 09:47 PM   #11
Steel Erection
Steel Erection's Avatar
Mine are 17" Wheel Vintiques. 8" in front 9" in rear. I have them installed over 13" Wilwoods.
Steel Erection is offline   Reply With Quote
Old 08-21-2014, 12:29 AM   #12
Budget63
What size tires are you running?
Budget63 is offline   Reply With Quote
Old 08-21-2014, 12:32 AM   #13
Steel Erection
255/40 front and 285/40 rear.
Old 08-21-2014, 03:01 AM   #14
Paul Y
Mr. Steel,
What series are they? And the backspacing?
Would be interested to know the drop as well. Looks tough!
P.
Old 08-21-2014, 06:48 PM   #15
Steel Erection
Originally Posted by Paul Y View Post
Mr. Steel,
P.
Thanks! 68 series. 4.5" front / 5" rear backspacing. 5 1/2" drop in front (3" springs and 2 1/2" drop spindle. 4" drop springs in rear.
Old 08-21-2014, 08:28 PM   #16
Really like the looks of those wheels!
Old 01-10-2015, 10:44 AM   #17
bpmathy
I'm going for 17" 8/9 stagger aluminum wheels from Year One. Right at a Grand with caps and lugs. Mimic the rally wheels, all the less weight. I also looked at the steels wheels, but this solution has more advantages.
bpmathy is offline   Reply With Quote
Old 01-10-2015, 11:51 AM   #18
blown240
blown240's Avatar
I'm pretty sure full size spares from a mid 2000s Toyota Sequoia have the vintage steel wheel look and are 17s. I'll see if I can take the one from my wife's Sequoia and test fit it to my 61.
'61 Panel - Helms Bakery Truck - Daily Driver - FOR SALE
blown240 is offline   Reply With Quote
Old 01-10-2015, 05:02 PM   #19
Grizz1963
Grizz1963's Avatar
Paul, what about looking around in the UK at options like Transit or other 3 ton type wheels?
Also, ask on Retro Rides or go look on Wheel whores.com there are some knowlegeable people out there.
One other option could be welding up existing holes and getting new ones, or is that too risky?
Last idea would be if you knew where wheels were made, to have a set of steels punched with the holes the way you needed them, I remember years ago when I was involved in offroad racing in South Africa, we used to get Mercedes Benz wheels dome in different stud patterns.
MY BUILD LINK: http://67-72chevytrucks.com/vboard/s...585901]Redneck Express - 1966 C10 Short Fleetside
MY USA ROADTRIPS http://forum.retro-rides.org/thread/...2018-humdinger
IF YOU CAN'T FIX IT WITH A HAMMER, YOU'VE GOT AN ELECTRICAL PROBLEM MATE.
Grizz1963 is offline   Reply With Quote
