Old 08-17-2014, 07:53 PM   #1
donthekawguy
donthekawguy's Avatar
non power MC for disc drum
My truck is at the shop for brake lines, steering shaft shortening and final check before I start driving it. I put on front disc brakes from a 85. I picked up a MC and booster for a 70-72 Impala. I got thinking the other day that my cam might be too big to have power brakes. I will have the brake guy check the vacuum in the morning when I swing by after work. If it isn't making enough vacuum, what MC should I use? I need a two pot manual disc/drum MC. I will keep the Impala set up for when I do a motor swap next year.
66 shorty
donthekawguy is offline   Reply With Quote
Old 08-17-2014, 07:55 PM   #2
hopped up
hopped up's Avatar
Re: non power MC for disc drum
67 Chevy truck m/c?
hopped up is offline   Reply With Quote
Old 08-17-2014, 09:05 PM   #3
Any 71/72 truck MC should work as long as you have the proportioning valve for the front disks. I think it is pretty much a bolt in replacement when not using the booster.
I have also see folks use the 73-87 style hydroboost off the 3/4 & 1 ton trucks.
Old 08-18-2014, 12:41 AM   #4
Captainfab
60-66 Nut
You can use a '71-'87 manual brake master cylinder. Or another trip to Pull And Save for a hydroboost.
Old 08-18-2014, 07:01 AM   #5
donthekawguy
I hope I have enough vacuum. lol If not I might go with hydroboost and save the MC/booster for another truck down the road. But to get it on the road I will go with non power for the rest of this year. Thanx for the help!
66 shorty
Old 08-23-2014, 10:50 PM   #6
bama63
bama63's Avatar
72 vette 1" manual master cylinder $24.00 at rockauto.com , direct bolt on and stops on a dime.
Due to financial constraints, the light at the end of the tunnel will be shut off until further notice
bama63 is offline   Reply With Quote
Old 08-23-2014, 10:58 PM   #7
Cooper197
Cooper197's Avatar
I kept the original M/C with my truck. Works great! Then again, I'm using McGaughy discs, so that may be part of it.
Cooper197 is offline   Reply With Quote
Old 08-24-2014, 03:36 AM   #8
donthekawguy
I had the single pot MC and those things are unsafe. And I want the truck to be safe and comfy.
66 shorty
Old 08-25-2014, 12:37 AM   #9
Captainfab
60-66 Nut
Did you find out yet if your engine produces enough vacuum for a vacuum booster? I have my doubts with that big cam, but thought I'd ask.
