Old 08-17-2014, 08:44 PM   #1
CST10
CST10's Avatar
454 BBC spark plug recommendation.
I have a low compression (8.2:1) 454 bbc engine that I currently use ac delco R44T plugs in. They tend to foul out after a few thousand miles due slightly oil or running slightly rich. Truck doesn't smoke any from the exhaust. Engine is mild by bbc standards.
Wondering what others are running in their trucks with similar set ups?
I have been advised to stay with the R44T, use a R44TS, use a R45TS, etc, etc.
What are you using?
MyToys:
Goldilocks the "Ol School Survivor" 1968 C10, SWB Stepside, 08/15 TOTM, 250 CI 6 cylinder, 3 on the tree, 3.73 rear, 3/5 static drop, 23,500 original miles.
Samson the 1970 CST10, LWB, 462Ci, Turbo 350 tranny, 3.08 rear gear, PB, PS, A/C, AM/FM, 2/4 Drop.
Brutus the 1998 Camaro Z28, 33,500 original miles, LS1, 519 RWHP/497 RWTQ.
Member of the Louisiana Classic Truck Club, LCTC
Member of the Louisiana C10 Club
Member of the Baton Rouge Drifters Car Club
CST10 is offline   Reply With Quote
Old 08-18-2014, 04:41 PM   #2
CST10
CST10's Avatar
Re: 454 BBC spark plug recommendation.
Anyone?
MyToys:
Old 08-18-2014, 06:42 PM   #3
Alex V.
Alex V.'s Avatar
Is it the same few cylinders consistently, or is there no pattern to which cylinders foul?
Alex V.
1967 C10 Suburban, 350/NP435, Green/Green, PS, PB, HD cooling, charging, shocks, and springs.
1985 GMC C3500 SRW, Sierra Classic, 454/TH400, white/blue.
Alex V. is offline   Reply With Quote
Old 08-18-2014, 09:21 PM   #4
kwmech
The ts designation is an extended tip. protrudes the tip about1/8'' or 3/16s.. I would step up the heat range and see what happens... So r45ts.. Also, what year? HEI?
Old 08-19-2014, 05:24 PM   #5
CST10
CST10's Avatar
Got a HEI distributor. The fouling is about the same across all the cylinders. Looking to have a self cleaning plug installed. It appears the the R44T plugs maybe too cold for putting around town. Runs fine. Just scared the they may gove me issues soon
MyToys:
Old 08-19-2014, 09:42 PM   #6
Alex V.
Alex V.'s Avatar
Yeah, if all you do is run it around below highway speeds it won't keep the combustion chamber as clean. I've run R44's (think they were just "T"'s) in my '85 1-ton (454) until this last time when all my FLAPS had was R45's, and they're performing fine so far. I don't think I've even put enough miles on them yet to take them out and check the gap.
Alex V.
Old 08-19-2014, 10:47 PM   #7
chip46wis
For years all us local BB 454/396 lovers ran r44C commercial plugs they last 3-4 times as long and I would go 1 step hotter----good luck
chip46wis is offline   Reply With Quote
Old 08-20-2014, 06:20 PM   #8
CST10
CST10's Avatar
Thanks guys. I bought some R44TS. Suppose to extend into the cylinder a little more to prevent early fouling. We will see how they do. I got flat top pistons so clearance shouldn't be an issue in the cylinder.
MyToys:
