Energy Suspension Master Set 4x4 73-80 3.18104g
Bought for a project that isn't happening.... $150.00 Shipped in the lower 48
HYPER - FLEX SYSTEM PERFORMANCE POLYURETHANE BUSHING KIT FOR 73-80 CHEVY GMC 4WD New in the box; opened only for photos & inspection. These sets usually sell for $210.00 shipped. Save $60 by buying these!!! FREE U.P.S. Shipping in the US ...... 18# box. Brand:Energy Suspension Manufacturer's Part Number:3-18104G Part Type:Bushing Kits Product Line:Energy Suspension Hyperflex Bushing Kits Summit Racing Part Number:ENS-3-18104G UPC:703639277323 Bushing Material:Polyurethane Bushing Color:Black Front Control Arm Bushings Included:No Rear Control Arm Bushings Included:No Front Sway Bar Bushings Included:Yes Front Sway Bar Bushings Greasable:No Rear Sway Bar Bushings Included:No Rear Sway Bar Bushings Greasable:No Front Sway Bar End Links Included:No Rear Sway Bar End Links Included:No Steering Rack Bushings Included:No Body Mounts Included:Yes Radius Arm Bushings Included:No Front Strut Rod Bushings Included:No Rear Strut Rod Bushings Included:No C-Bushings Included:No Axle Pivot Bushings Included:No Front Track Arm Bushings Included:No Rear Track Arm Bushings Included:No Front Coil Spring Isolators Included:No Rear Coil Spring Isolators Included:No Front Leaf Spring Bushings Included:Yes Rear Leaf Spring Bushings Included:Yes Front Leaf Spring Shackle Bushing Included:Yes Rear Leaf Spring Shackle Bushings Included:Yes Transmission Shift Stabilizers Included:No Transmission Mount Included:Yes Transmission Crossmember to Frame Bushing Included:No Rear Trailing Arm Bushings Included:No Torque Arm Mounts Included:No Strut Tower Bushings Included:No Rear Panhard Bar Bushings Included:No Rear Leaf Spring Pads Included:No Rear Spring Cushions Included:No Front Shock Bushings Included:No Rear Shock Bushings Included:No Rear Subframe Bushings Included:No Differential Pinion Bushings Included:No Rear Differential Carrier Bushings Included:No Ball Joint Dust Boots Included:Yes Tie Rod End Dust Boots Included:Yes Steering Coupler Bushings Included:No Rear Overload Spring Snubbers Included:No Rear Watts Link Bushings Included:No Front Axle Bump Stops Included:No Transmission Torque Arm Bushings Included:No Motor Mounts Included:No Bar End Grommets Included:No Lower Control Arm Bump Stops Included:No Front Bump Stops Included:No Rear Bump Stops Included:No Power Steering Ram Bushings Included:No Differential Carrier Mustache Bar Bushing Included:No Quantity:Sold as a kit.
1994 C1500 rclb 1988 C1500 rclb 1969 ES5500 B E A S T 1983 C10 'farm truck' 1976 K20 Suburban 1984 K10 Suburban 1981 Jeep CJ5/350 Vortec 1941 Dodge WC18 Ambulance 2000 GMC Bus (parts warehouse) |
Re: Energy Suspension Master Set 4x4 73-80 3.18104g
SOLD, Thanks...........
