Clutch going out 10 or 11 in
My 62 clutch is going out and I was wondering what size is it. Is it 10 or 11 in? I am still recovering from surgery and I can't pull it apart yet. I would like to get it and have it ready. It's got the original 235 with the three speed.
John Z 1962 Chevy C10 Stepside 62 Barnfind My build tread: http://67-72chevytrucks.com/vboard/s...d.php?t=507513 |
Re: Clutch going out 10 or 11 in
More than likely its a 10.5 or 11 and you wont know with out taking it out. My trucks all came with 10.5, but I reinstall 11 clutches.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
Mine was 11 inch. When I swapped over to T5 fine 26 spline I went 10 because the only clutch out there at that time was a Viper, with its double the cost for that 1" .
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats http://www.cardomain.com/ride/332579...t-c-k-pick-up/ http://67-72chevytrucks.com/vboard/s...d.php?t=560081 |
Thanks for the help. When I have it in gear I totally lose the clutch, when I hold it for a while. Then I pump the pedal and I have it again. I have replaced the master and slave in the truck already but it has been a year ago. I looked at it with someone else holding the clutch pedal down and the slave and push rod didn't move. I'm still not sure if it is the slave or master cylinder.
if the rod dont move when pumping the pedal and its not puking fluid all over the ground then your master is toast
The rod is moving but I loose the clutch after I hold it down for a while. The slave cylinder is engaged but I loose the pedal and the truck starts to move. So I can't really diagnosis the problem. No leaks and clutch works fine if you don't hold it down for a while. I'm thinking it's the master cylinder also.
Yes, it sounds like the master cylinder is leaking internally and bleeding down.
its master for sure
I had a holy hose from master to slave.
one should be able to see the brake fluid to see where it is leaking from. a lot of times you can see it on the inside of the firewall
ron |
I think it's internal. I don't see any fluid on the fire wall or ground. It does work only if you use the clutch for a short period and if I hold it down i have to pump it back up to get a pedal. I just re-verfied it again and it is bleeding down somewhere. I'll go get me another master cylinder and try it out. Thats why I like this site. Thanks for all your help!
you may still have air in the system. try bleeding it some more. if fluid is leaking out it is going somewhere. if the master is leaking it usually shows up inside the cab where the pushrod goes into the master where the rubber boot is. just pull the rubber back to check for wetness.
if it is an internal leak then that is air and as above; bleed it. also check your fittings for loose. it doesn't take much ron |
#13 | |
#14 | |
ron |
#15 | |
What do you mean by "what is displacing the fluid that is leaking internally?"? All the master cylinders I've dealt with have the front seal that builds pressure, and another behind it that keeps fluid from escaping and the cylinder from sucking air on the return stroke (I think/guess? Never really researched it). If the front leaks, the pressure just bleeds back into the reservoir--which is what sounds like is happening.
1965 C30 pickup 350/SM420/4.10's (daily driver) thread 1968 Impala 4 door sedan (future driver project) thread Last edited by 66Submarine; 08-18-2014 at 10:06 PM. |
#16 |
Today I replace the master cylinder and it corrected the problem. Thanks to everybody for saving me some time in the troubleshooting process. Works great!
