lmc LED taillight install (blinker??)
I purchased the lmc LED taillights for my 61GMC. I already have an Ididit column and planned to replace all the factory wiring. BUt the new taillights only have a brake, and a running light wire. No provision for blinker. How has this been handled by others?
Also, I installed LED front parking lights in the hood, and they are single filament. I want to use them as running lights AND blinkers. It seems the only solution is to run two trailer convertors. Just hoping others could post their experience and solution. |
Re: lmc LED taillight install (blinker??)
SteveM--your lights only have two wires, running lights and brake and turn
1961 chevy K10 my build is------------61K10 build |
So does everyone just run A trailer type tail light converter then?
Maybe I'm missing something. I don't have my original rear harness anymore. Is there something within the flasher circuit that already handled this for me and I just don't know what?
But yes. My LMC taillights only have two wires as you stated |
the turn sig/switch in your column controls the blinkers
So is this basically what happens for your trucks then too?
Essentially it seems the signal switch diverts power through the flasher for the bulb in question while keeping the other brake light on. Now, if I can figure out a way to combine the hood mounted parking lights into this figure. |
1965 Chevy C10, 2005 4.8L/4l60
![]() Join Date: Aug 2004
Your front "marker" lights are supposed to go out when your headlights are turned on.
Is this what your referring to?
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
Steve there is a way to use them as running lights. you run a jumper in your light switch. sorry don't remember the process. maybe in the electrical faq's or somebody will chime in.
EDIT: I had the link below saved on my computer because I planned to use the hood lights as markers when my headlights were on. But now it looks like the links in post #3 are broken. Rats.
See post #3 in the link below. It has 2 different links for different year trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=577029
My 65 C10 build: www.lugnutz65chevystepside.weebly.com Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild. |
