Old 08-18-2014, 01:32 PM   #1
grad70
unknown truck manifold port
I have started a L96/4l80e swap into my '70 c10. I am having issues determining what the port is for on the passenger side of the truck intake manifold. I'm on a work trip so I can't take anymore pics than what I have below. I'm hoping to find out where it should go/connect to before o get back in case I need to order more parts.
I have used this site a lot to get to where I'm currently at and wanted to thank you ahead of time. I have been unable to find this info for the last week of searching.
grad70 is offline   Reply With Quote
Old 08-18-2014, 01:37 PM   #2
grad70
Re: unknown truck manifold port
I was unable to circle the actual area I'm asking about but its the vent/vacuum/whatever in the black plastic molding (intake manifold).
Old 08-18-2014, 01:45 PM   #3
truckdude239
truckdude239's Avatar
it was used for vacumm in the hvac system just put a rubber cap over it
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2015 toyota Tacoma Daily
2012 Subura outback
2000 Tahoe 5.3l 420k
1999 honda accord
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 08-18-2014, 03:11 PM   #4
69gmcc10
69gmcc10's Avatar
On my truck that port was blocked off from the factory. I broke the tang off so I could use it as an access port to run sea foam through the intake every so often and I just use a rubber plug to block it off the rest of the time.
Block it off and you will be just fine.
69 GMC C10 build thread- http://67-72chevytrucks.com/vboard/s...d.php?t=501676
03 Silverado build thread-http://67-72chevytrucks.com/vboard/s...d.php?t=591582
69gmcc10 is offline   Reply With Quote
Old 08-18-2014, 07:14 PM   #5
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
As they mentioned, its an a vac port that is 90% unused. Most of the time it'll have a black or red cap in/on it. You can plug it if it doesn't. Some folks "shave" and plug it, but if you use an engine cover you'll never see it anyway.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 08-19-2014, 02:01 PM   #6
grad70
Thanks!
I'm also able to block-off/cap the line for the vapor canister as well? I have the speartech harness so the emissions should be taken care of in the ecm.
Old 08-19-2014, 03:47 PM   #7
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
You can plug the hole, or just leave it sitting there. The unit is normall OFF, so if its not wired up, it plugs its own hole. You only need a physical plug if you remove the whole EVAP from the intake manifold.
