08-18-2014, 02:33 PM | #1 |
serpentine setup with pulleys and accessories $160.00 shipped
I have a serpentine setup from a 90? Chevy truck. All the accessories ( alt, power steering, a/c compressor, harmonic balancer w crank shaft pulley ) included. I also believe I have all the bolts too. This setup doesn't have a smog pump provision. Will need cleaned up, it's pretty dirty $160.00 shipped
I'll get pictures of the setup tonight after work. Thanks, Scott Duckworth 913-314-6233
Scott Last edited by sduckworth13; 08-18-2014 at 03:17 PM. |
08-21-2014, 03:33 PM | #2 |
Re: serpentine setup with pulleys and accessories $160.00 shipped
Bump
A husband can be right...or...A husband can be happy. 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
08-21-2014, 03:35 PM | #3 |
Thank you I'll get pictures tonight.
Scott |
08-21-2014, 04:47 PM | #4 |
That's a good buy for somebody!!!!
Jason '70 C-10 short fleet 427BB TH400 (SOLD) '10 Ford F 350 '13 Ford RAPTOR 6.2 MY BUILD THREAD http://www.67-72chevytrucks.com/vboa...d.php?t=612623 |
08-21-2014, 06:08 PM | #5 |
Scott |
08-21-2014, 06:10 PM | #6 |
Here is a picture of the serpentine setup
Scott |
08-22-2014, 10:32 AM | #7 |
Bump for a great deal.
I did this conversion and can tell you this is a good deal. |
08-22-2014, 10:39 AM | #8 |
Will this fit a Chevy 350 engine? And do you have any pics from when it was on the engine (it would help me visualize it)?
___________________________________________ Darien 1971 C10 LWB http://67-72chevytrucks.com/vboard/s...d.php?t=502964 |
08-22-2014, 10:40 AM | #9 |
Yep
08-22-2014, 10:42 AM | #10 |
You will need the correct "reverse rotation" water pump.
08-22-2014, 11:11 AM | #11 | |
I don't have any pictures of everything installed. I bought this from a friend of mine for $100.00 and he just have me everything for it in a bucket.
Scott |
08-22-2014, 11:20 AM | #12 | |
If someone else wants it in the meantime, go ahead and sell it. That will make my decision easier. :-)
08-22-2014, 11:26 AM | #13 | |
Scott |
08-22-2014, 11:42 AM | #14 |
That is probably an offer I can't refuse... The wife might kill me, but let's do this. It comes with all brackets, right (I don't see the a/c compressor in the pic, so I have to ask)? I need something I can basically bolt into my engine.
Thanks for the price break; I really appreciate it. You have helped me and made my things more difficult at the same time!
08-22-2014, 11:44 AM | #15 |
One more question, do you know what exactly what type of truck this came off? Or what type of belt it uses? I need to know how to search for the belt for it.
08-22-2014, 12:02 PM | #16 | |
I'm not sure on the part number but just ask for the belt that doesn't have the smog pump. I believe this came off a 94? 4.3 not real sure. There are part numbers on the casting to help you get the right belt. It will fit a 1995 C1500 5.3 and many others.
Scott |
08-22-2014, 12:06 PM | #17 |
Do you know what heads you have, I know that some heads don't have a bolt hole for one bolt that attaches to the serpentine assembly, but a lot of people still use them without issue without that bolt.
Scott |
08-22-2014, 12:07 PM | #18 | |
08-22-2014, 12:15 PM | #19 |
PM sent
Scott |
08-22-2014, 12:20 PM | #20 | |
Of course I realized after uploading that the first pic shows the wrong side of the engine! Thanks for your help with this.
08-22-2014, 12:22 PM | #21 |
Here is the A/C compressor. It is attached to the serpentine assembly and it will attach on the right side of the engine.
Scott |
08-22-2014, 12:24 PM | #22 |
Oh, okay. I am really not familiar with belt driven systems, so I did not know what I was looking at. Thanks!
08-22-2014, 12:27 PM | #23 |
This should work out fine, I think it was some early vortecs that didn't have the accessory hole in the front of the head.
Scott |
08-22-2014, 12:29 PM | #24 |
That's a good looking engine you have. I'm getting ready to rebuild mine so I'm trying to clear out some space in the garage so when Vic ( Vic1947 ) comes over he has room to work.
Scott |
08-22-2014, 12:51 PM | #25 | |
Do you know if the drivebelt system would take a long or short water pump? If not, I can figure it out when I get it.
