Old 08-18-2014, 05:48 PM   #1
76er
Turn Signals
What was the first year of the task force trucks that turn signals were standard equipment?
76er is offline   Reply With Quote
Old 08-18-2014, 05:59 PM   #2
dwcsr
Hollister Road Co.
dwcsr's Avatar
Re: Turn Signals
Directional Signals: Available as an accessory not an option, so to answer the question no task force truck came with signals as standard equipment
dwcsr is offline   Reply With Quote
Old 08-19-2014, 08:56 AM   #3
76er
Re: Turn Signals
I have one of the old accessory ones that is in shambles, where can i buy a new one with the correct number of wires, i've heard they have as many as 7 wires.
Old 08-19-2014, 02:25 PM   #4
dwcsr
Hollister Road Co.
dwcsr's Avatar
Re: Turn Signals
classicparts.com
americanclassic.com
Bowtiebits.com
any of them should have it
Old 08-19-2014, 03:11 PM   #5
OrrieG
OrrieG's Avatar
Re: Turn Signals
Here are the factory diagrams
OrrieG is offline   Reply With Quote
Old 08-19-2014, 08:17 PM   #6
76er
Re: Turn Signals
Thanks for all the useful info, guess what I really meant to ask is did chevy ever offer factory turn signals as an option or however built into the steering column as we know them today? I see in several of the parts catalogs such as Eklers where they sell the part of the column housing thst has the turn signal canceler with wiring for 1956 trucks.if so I would like to find one to put in my truck.
Old 08-19-2014, 08:59 PM   #7
dwcsr
Hollister Road Co.
dwcsr's Avatar
Re: Turn Signals
Originally Posted by 76er View Post
Thanks for all the useful info, guess what I really meant to ask is did chevy ever offer factory turn signals as an option or however built into the steering column as we know them today? I see in several of the parts catalogs such as Eklers where they sell the part of the column housing that has the turn signal canceler with wiring for 1956 trucks.if so I would like to find one to put in my truck.
Yes they did have it as an accessory that the dealer could add that was made by GM in a kit form. When you wanted signals on a new truck you would order your truck and the dealer would add them, AC was the same way or you could add it later on if you wanted but you could not order a TF truck and have factory installed signals. I believe that changed in 60
Old 08-19-2014, 09:36 PM   #8
rrenner
rrenner's Avatar
Re: Turn Signals
Has anyone mated the stock turn signal switch and wiring to a modern gm type? I have a speedway wiring harness that has an option for plugging into a gm column but I'm trying to use my stock column and turn signals. Any help would be appreciated.
rrenner is offline   Reply With Quote
Old 08-19-2014, 10:59 PM   #9
OrrieG
OrrieG's Avatar
Re: Turn Signals
Here us the later GM column wiring plug colors and what they are for. Except for the rear left and right turn they are the same as the TF era. My wiring kit came with the column wires terminated but loose, I had to stuff them into the plastic connector, you would just need to do the same up under the dash. Note A-F are used on higher optioned cars like Caddys for other light related stuff.
Old 08-20-2014, 06:44 AM   #10
76er
Re: Turn Signals
Great info, thanks all
Old 08-20-2014, 03:30 PM   #11
rrenner
rrenner's Avatar
Re: Turn Signals
Thanks Orrie, as always a big help!
