Old 08-18-2014, 07:19 PM   #1
MountainGoat1966
Differential install tips needed.
I'm getting ready to install a fresh differential carrier in the front axle of my 84 K10 with the corporate 10 bolt 8.5"
I am using my existing ring & pinion gears, changing from an open carrier to a limited slip unit.
Mainly because the current carrier has worn out spider gear splines for the axles, and a LS will help with the horrible mud I get here after a storm.
I have all the parts I need including shims and axle tube seals.
I won't be using a differential spreader, so any tips would be appreciated as to how to safely R&R the carrier and not damage the shims or anything else.
"Off the grid and on the seven day weekend plan"
"One person cannot know everything, but between all of us, there isn't much we don't know."
MountainGoat1966 is offline   Reply With Quote
