08-18-2014, 08:51 PM | #1 |
Question_My Truck Drives Sideways??
My brother was driving my truck and I was following in his car when I noticed that my truck looked like it was going down the road sideways. I could see the front drivers side tire from directly behind the truck. Can I fix this? Is this a major issue to tackle?
Hope this makes sense! I tried searching it, but couldn't come up with much. Sean |
08-18-2014, 08:52 PM | #2 |
Re: Question_My Truck Drives Sideways??
Frame bent?
08-18-2014, 08:54 PM | #3 |
alignment, ck Thrust angle
08-18-2014, 08:56 PM | #4 |
08-18-2014, 09:00 PM | #5 |
Leaf springs? Might have the rear end knocked out of alignment if so (mine does).
08-18-2014, 09:05 PM | #6 | ||
Could be the alignment. I don't think it was ever set after the Ididit steering rack went in. That was before I owned the truck.
Sounding like a bent frame, which also sounds expensive... |
08-18-2014, 09:08 PM | #7 |
mine did that i replaced track bar with a adjustable one. I also replaced the trailing arm bushings, rear springs due to them being pointed over to one side.
mine drives strait now. get a tape out and measure the wheel base side to side, if one side differs from the other it could be the trailing arm bushings.
Between saying and doing many a pair of shoes are worn out |
08-18-2014, 09:10 PM | #8 |
Mine does that a little the front was converted to leafs and they didn't line them up right
AJ |
08-18-2014, 09:13 PM | #9 | |
08-18-2014, 09:17 PM | #10 |
if the bushings haven't ben done just remember there almost 50 years old and they are cheep parts. nothing a saturday afternoon a hammer and some wood cant fix
08-18-2014, 09:28 PM | #11 |
If you take a tape measure from the front fender line at the front of the doors to the front of the rear wheels i bet you that the right side is farther back than the left and since you said you don't have leaf springs that takes out a center bolt problem ...SO i would say your right trailing arm bushing is gone... or the right U bolts are loose and the axle has shifted some how (less likely) i doubt the pan-hard bar could be bad enough to make it DOG-TRACK that bad
08-18-2014, 10:04 PM | #12 |
Senior Enthusiast
If it's a stepside and only looks a little crooked, it can also be optics. Because the 1955 bed is too narrow for the cab, you can easily see the side of the cab making the truck look like it's dog tracking. Getting in the right lane and following behind the right rear tire can make it appear to be dog tracking the other direction.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502 |
08-18-2014, 11:03 PM | #13 | |||
Thanks for all the advice guys! Feeling a lot better about it now. Sean |
08-19-2014, 12:40 PM | #14 |
Have it checked out but more than likely it's an optical illusion. If your in the right place at the right time any car or truck will look like it's crooked going down the road.
66 shorty |
08-20-2014, 02:01 PM | #15 |
I would think it's an illusion too. My old 94 chevrolet had aftermarket wheels and larger all terrain tires, the wheels offset stuck the tires out more upfront than in the rear. Gave the illusion that it was driving sideways.
1961 C60 Viking 8' Dump 261 SM420 2-Speed Rear 1966 C10 Fleetside 350 W/ Saginaw 4 speed 1985 K10 Chevy 6.2 diesel 700r4 longbed 2001 Dodge 3500 Dually 24v NV5600 4x4 USMC Reserves Jason |
