Old 08-19-2014, 02:35 AM   #1
wolffcub
wolffcub's Avatar
What plugs are you running in your 41955 235"
Just wondering what others are running on their trucks. I running the NGK Br6S ones. Had my truck out today for it first real drive. Took out the plugs to take a look at them and it was a bit white. Think i need to also richen up the mixture a bit.
wolffcub is offline   Reply With Quote
Old 08-19-2014, 04:34 PM   #2
AZ59apacheguy
Re: What plugs are you running in your 41955 235"
The idle mixture screw is just for that, idle. Once you get into speed it's your internal jets that determine fuel/air mixture. You might have to change your jet. I'm sure someone else will chime in on this too. Good luck
AZ59apacheguy is offline   Reply With Quote
