08-19-2014, 12:33 PM | #1 |
Power Booster & Master Cylinder Question
Hey Guys,
I'm going to add a power brake system to my Sub. I was planning on keeping the drum brakes all around. My question is do I still need to have the proportioning valve? I know I would need it, if I switched the front to disc, but since I'm not. I wasn't sure. If you guys could pass on that the expertise that you have, it would be great! Thanks in advance. |
08-20-2014, 12:33 AM | #2 |
60-66 Nut
Re: Power Booster & Master Cylinder Question
No you do not need a proportioning valve with drum/drums. The '67-'70 booster and master cylinder is what I recommend for use with a drum/drum system. That booster is compatible with my booster brackets also.
08-20-2014, 12:27 PM | #3 |
Thanks for the info Captainfab!
09-02-2014, 04:41 PM | #4 |
One more question on this guys. Does it matter what size booster I get, when swithing to power brakes? I'm looking at either 9" or 11" booster.
09-03-2014, 01:15 AM | #5 |
60-66 Nut
What size and type of booster will depend partly on how much vacuum your engine produces. The larger the diameter the more power assist you will get from a given vacuum. The same for a dual diaphram versus a single diaphram booster. And then there is hydroboost if the engine vacuum is just too low.
09-03-2014, 01:22 PM | #6 |
I have a 283 in the truck, so I'm not sure how much vacuum there is. Guess that's something I'm going to have to look into.
09-03-2014, 02:01 PM | #7 | |
I am contemplating updating the single pot m/c in my '63 Grand Prix to a dual system, which is why I ask. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
09-05-2014, 01:31 AM | #8 | |
60-66 Nut
I am not aware of a proportioning valve for the drum/drum brake system. Of course most of my knowledge is with the trucks. The '67-'70 trucks use what I call a distribution block. It is basically 2 ports in, 2 ports out.
My '68 Camaro with drums/drums has a similar distribution valve To answer your question, if either the front or rear circuit were to develop a leak, there is no shuttle to shut off flow to that side. But you should still have limited braking ability to the other side. Quote:
