Old 08-19-2014, 03:16 PM   #1
HEADTURNINGC10
1984 k10 traction bars or other ideas
I have a 1984 k10 short bed. looking for some help with a traction bar or something to prevent axle wrap and help traction. I know off road design makes one i was hoping maybe someone could help give me ideas to make one and other routes i would prefer two bars (the look is sweet). its stock height now but plan on going with four inch lift.
This is off road designs setup.
If yall are running something simuilar please hake pictures
HEADTURNINGC10 is offline   Reply With Quote
Old 08-19-2014, 10:32 PM   #2
andrewmp6
Re: 1984 k10 traction bars or other ideas
Have you looked at http://www.landlproducts.com/list.aspx?cID=5
andrewmp6 is offline   Reply With Quote
Old 08-20-2014, 07:30 AM   #3
HEADTURNINGC10
i have not thank you
Old 08-26-2014, 03:13 PM   #4
DWilbur
My 84 K20 had the same problem I install double shocks 1 on each side of the rear axle.
solved the problem it had BB454.
DWilbur is offline   Reply With Quote
Old 08-26-2014, 04:50 PM   #5
HEADTURNINGC10
Did you get a kit or custom do you happen to have pictures
Old 08-26-2014, 11:35 PM   #6
DWilbur
I made my own parts out of 1/4" plate steel and welded them to the axle. drilled holes in the frame to match the stock location and bolted the 2 shocks in place. I don't have any pictures.
