08-19-2014, 03:40 PM | #1 |
What engine is this????
Hi guys im not new here but i read alot of different post here and love the pics here.... I have a question guys and gals... I have a hard to find 1966 GMC P10 steel body in (in progress) and its a L6 engine, I just convert it to a HEI dist but according to my timing marks,TDC is not were TDC is suppose to be so im starting out trying to find out what kinda of motor i have...it reads F0911PE (Flint,sep 11th XX) i check and check the forum and all kindas of websites but that PE is no were to be found
Also with the p10 engine,the timing marks (one notch pulley only) in pic are located at the bottom of the van,not the top like C-series. And the pic of the screw driver is shown to let you know where the number 1 piston is sitting.....Please advise. |
08-19-2014, 04:30 PM | #2 |
Re: What engine is this????
Casting # off the block would be useful too!! And some pictures of the whole engine. There are quite a few things that easily identify a 230/250 vs. 292
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer Last edited by 1963c-10; 08-19-2014 at 04:42 PM. |
08-19-2014, 04:45 PM | #3 |
1969 Chevy truck c-10 250 w/manual trans
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
08-19-2014, 06:30 PM | #4 |
Thank you for the fast reply, Im adding a pic of the complete engine now with numbers....please advise any other needs.
08-19-2014, 06:36 PM | #5 |
08-19-2014, 07:35 PM | #6 |
Hard to tell what casting numbers are. Can you list them? 39219_ _ is what I make out. Last 2 are 3' or 8's
08-19-2014, 07:35 PM | #7 |
Looks like a nice carb upgrade
08-19-2014, 08:44 PM | #8 |
Thanks again everybody, i just installed the carb set up,just need to tune it in. The numbers are 3921968...hope this helps.
08-19-2014, 09:19 PM | #9 |
probably has the harmonic off of a standard C model 250 (NOT the P that you have) on the crank look for another mark that someone may have filed in it if not then you will need to find top dead and mark it...... to find top dead take an old spark plug BREAK the ceramic out and braze a pin in it maybe 1 1/2" long screw it in the head #1 ....turn by hand till it hits.. TEMP. mark the harmonic then turn crank back the other way till it hits ...TEMP mark there then mark half way between the marks and you have TDC.... JUST NOTICED HI Neighbor JOSHUA TREE HERE
08-19-2014, 09:30 PM | #10 |
Looks to be a 250. Is that a Weber 32/36?
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
08-19-2014, 10:12 PM | #11 |
Hello fellow high dessert friend jtrichard, thanks for the info,ill try this method.
To follow up on the question about the carb, she a 32/36 weber. |
