Old 08-19-2014, 06:28 PM   #1
gferris5
gferris5's Avatar
Truckandcarshop Window Sweeps--Too long?
Hey Folks~
As we all know, the good folks at the repro product manufacturers try hard, but sometimes don't bring their A game.
I went to install new window sweeps (this is the felt inner and rubber outer piece that runs horizontally next to your window). After pulling out the old one gently, I went to put in the one from truckandcarshop, and it is about a quarter inch too long.
Am I supposed to force this thing, or Can I safely trim these things to fit? Has anyone else had this problem? I could see where trimming would cause a problem in terms of holding them in place. At the same time, they are definitely not the same size as the original ones.
Have mercy, I'm recovering from my 4x4 addiction.
gferris5 is offline   Reply With Quote
Old 08-19-2014, 08:34 PM   #2
CST10
CST10's Avatar
Re: Truckandcarshop Window Sweeps--Too long?
I have the same issue. So I haven't even pull the old ones. How do you replace them anyway. Do you have to remove stuff from the door or can you just roll the window down to replace them.
MyToys:
Goldilocks the "Ol School Survivor" 1968 C10, SWB Stepside, 08/15 TOTM, 250 CI 6 cylinder, 3 on the tree, 3.73 rear, 3/5 static drop, 23,500 original miles.
Samson the 1970 CST10, LWB, 462Ci, Turbo 350 tranny, 3.08 rear gear, PB, PS, A/C, AM/FM, 2/4 Drop.
Brutus the 1998 Camaro Z28, 33,500 original miles, LS1, 519 RWHP/497 RWTQ.
Member of the Louisiana Classic Truck Club, LCTC
Member of the Louisiana C10 Club
Member of the Baton Rouge Drifters Car Club
CST10 is offline   Reply With Quote
Old 08-19-2014, 08:45 PM   #3
michael bustamante
michael bustamante's Avatar
I have seen on past threads where owners have to trim the rubber right around the vent window
1967custom
michael bustamante is offline   Reply With Quote
Old 08-19-2014, 09:37 PM   #4
Tinkermc
Trim 2 fit, roll window all the way down 2 install.
Tinkermc is offline   Reply With Quote
Old 08-20-2014, 01:06 PM   #5
gferris5
gferris5's Avatar
Thanks for the replies everyone. I will trim to fit.
In case anyone else searches and finds this: the old ones are not that hard to pull out, roll the window down all the way and just use a thin screwdriver and very gently and slowly work them out. Most of my old clips just broke and fell down the door anyway. We'll see how it goes customizing the new ones...
Old 08-20-2014, 01:30 PM   #6
knomadd
knomadd's Avatar
I used some metal shears on mine (not from truck and car shop), and a file to clean up any sharp edges after I cut them. Just be sure to look at where the clips line up before you cut. I had to cut different ends on driver and passenger sides.
-Duane
C/10 Club Texas member
1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project)
1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby)
knomadd is offline   Reply With Quote
Old 08-20-2014, 05:53 PM   #7
BlackedOut67shorty
BlackedOut67shorty's Avatar
I had bad luck with my window sweeps, not sure if they were from the truck shop but mine just fell apart ��
1995 s10 blazer 4.3
1967 c10 350/350 fleet short
1993 s10 blazer 4.3l 4l60 RIP 6/20/14
2000 mercury sable
Thats a how I roll
BlackedOut67shorty is offline   Reply With Quote
Old 08-20-2014, 08:11 PM   #8
GMCGrim
GMCGrim's Avatar
I had to trim mine also. I used a Dremel with a cut off wheel,worked like a charm. I also thought to myself why can't these parts be made to fit like the originals? It seems like most things that we buy for these trucks from the aftermarket don't fit like the originals.
It's frustrating, because none of this stuff is cheap!
GMCGrim is offline   Reply With Quote
