Front Wheel Bearing
Easy enough replacement to do inner and outer on the old k10?
I did the passenger side 15 years ago. i drove it Monday for the first real ride since motor and tranny swap and can feel it clunking. Checked the bearings and there is play. Any hints would be helpful. I will pull the maintenance book back out and find the tool. |
Re: Front Wheel Bearing
As long as you know how to hand pack a bearing with grease and how to properly set the tension on them you are golden.
