Old 08-20-2014, 01:37 PM   #1
jimcaf
jimcaf's Avatar
LS1 with 4.11 gears
Just got done with my LS1 swap 4L60E ,28 inch tires,its got 3.08s gear right now and getting ready to stick 4.11s in it .. Im in SoCal and drive up a pretty substantial hill to get to my house and plan on putting a hitch on it for the occasional tow. From what I gather out here the gear of choice is 3.73..Do you think I will regret it??,,,,thanks jim
1971 Chevy C-10, 5.3, 4L60E,4.10 gears UNDER CONSTRUCTION
Mid size bed conversion https://picasaweb.google.com/1114721...yC10MidSizeBed
The basic buildup https://picasaweb.google.com/1114721...3/1971ChevyC10
jimcaf is offline   Reply With Quote
Old 08-20-2014, 02:45 PM   #2
chuckmc8
It's alsways something.....
chuckmc8's Avatar
Re: LS1 with 4.11 gears
One of my donor trucks was a LQ4 with 4l80 and it had 4:10 gears from the factory (2WD 2002 2500HD)
1968 RS Camaro 'Vert Matching number 327 and M21 Muncie
1968 C10 Black with red interior and orig paint. 5.3 / 4l60e,3:73 POSI 17" Torq Thrusts
1968 CST 514 Red with black interior. Buddy Buckets, Factory A/C, PS, PB- 20" AR custom shop TT, 5.3 and 4l60e
chuckmc8 is offline   Reply With Quote
Old 08-20-2014, 03:32 PM   #3
trac209
Personally with a 4le trans I'd go with the 3.73. These trucks are far lighter then the donors ls engines come out of,3.73 should be plenty of gear and make for a better highway cruiser.
trac209 is offline   Reply With Quote
Old 08-21-2014, 12:17 AM   #4
BigRed76
BigRed76's Avatar
My '71 that I LS swapped has a 3.73 rear w/ 29" tires and its pretty much perfect for the setup. I'd think 4.11 is too much.
Zach
1970 Chevrolet Custom Camper K20
1971 GMC Super K2500, 12V/NV4500 swap in progress
1971 Chevrolet Custom C10
1972 Chevrolet Custom Deluxe C20, 5.3/4L60E
1972 Oldsmobile Cutlass Supreme, 455/TH400, 3.73 posi
2004 GMC Sierra 2500HD, LB7/Allison, CCSB
2005 GMC Sierra 1500, 5.3/4L60E, CCSB
BigRed76 is offline   Reply With Quote
Old 08-21-2014, 01:40 AM   #5
Andy4639
Old member
Andy4639's Avatar
Talking Re: LS1 with 4.11 gears
I just had the 6.0 LQ4 with 4l80e auto installed back in Jan. The rear end gear is factory 4:10's and I like it. I could go a little less I'm sure but with the weight of these old trucks I'll stay right where I'm at. I don't get the best gas milage but at 17.5MPG I'm ok with it since I didn't buy the truck for gas milage anyway!
The take off is great and it doesn't cruise bad at all only 2200RPM's at 65-70 MPH. If I do anything else it will be to add the new 6 speed automatic later to help on gas.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 08-21-2014, 07:17 AM   #6
You'll find 4.10s came in 2500/3500s with taller tires. I would want 3.73s for your lighter truck with shorter tires. I have hauled many serious loads with 3.73s. I never felt I had the wrong ratio
Old 08-21-2014, 09:27 AM   #7
Custom 68
Custom 68's Avatar
I will vote for 3.73 also, I used that for several years and was a great combo. I did swap to a t56 and did swap to the 4.11 at that time because of the double overdrive.
the 4l60 has a very low first gear so with the lower gearing you will find first is a very short gear for you.
doing the quick calculation for the upper end it probably is about a wash. at 70 the 4.11 gears will cruise at 2400, the 3.73 will net you 2200. Not much difference.
Dave
1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap
1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?)
"A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome".
"If it doesn't fit force it...If it breaks then it needed to be replaced anyway!"
Custom 68 is offline   Reply With Quote
Old 08-21-2014, 06:25 PM   #8
Hart_Rod
Hart_Rod's Avatar
3.73s....
Hart_Rod is offline   Reply With Quote
