Old 08-20-2014, 09:19 PM   #1
c10 custom
c-notch install help 68 chev truck
Hi everybody i bought a c-notch kit from classic performance parts
i was wondering if anybody had any step by step procedure
to install the c-notch kit on my truck any help would be great
pictures anything thanks eveybody
c10 custom is offline   Reply With Quote
Old 08-20-2014, 09:57 PM   #2
68shortwide
68shortwide's Avatar
Re: c-notch install help 68 chev truck
Uh. C notch isn't really something you wanna try n do if you don't know what you're doing, prolly better off finding a shop to do it, It'll cost more but it'll be done right.
Jack
Personal Fleet: Family Fleet:
1955.5 Panel 1959 Apache
1968 ShortWide
1969 ShortStep
68shortwide is offline   Reply With Quote
Old 08-20-2014, 10:08 PM   #3
sduckworth13
sduckworth13's Avatar
Here you go. http://67-72chevytrucks.com/vboard/s...d.php?t=196013
Good luck with your install. Just make sure you don't remove too much frame where you could possibly create a large gap that will need welded up. You want every bit of the C- notch touching the frame notch...just take your time.
Scott
sduckworth13 is offline   Reply With Quote
Old 08-20-2014, 10:43 PM   #4
sduckworth13
If you have the budget for a Porterbuilt 2 piece C-notch it really is the way to go. It is so easy to install once you get pass all the rivets that need removed first. The metal is 2x thicker than all the one piece c-notches.
Scott
Old 08-21-2014, 02:05 AM   #5
RManson
Hope this helps!
http://www.customclassictrucks.com/t...e/viewall.html
RManson is offline   Reply With Quote
Old 08-21-2014, 02:45 AM   #6
track70
track70's Avatar
Pics of my install..I welded mine instead of bolting it..Hope this helps
TRACK70 BUILD -> http://67-72chevytrucks.com/vboard/s...d.php?t=589761
King's Speed Shop
track70 is offline   Reply With Quote
Old 08-21-2014, 11:06 AM   #7
csfields
csfields's Avatar
I did my own. I recommend using an air chisel to knock out all the rivets. That was the worst part of it.
Thanks,
Casey
71 Chevy C-10 SWB 350/400 PS, PB
The Build http://67-72chevytrucks.com/vboard/s...d.php?t=584045
The Brake Upgrade http://67-72chevytrucks.com/vboard/s...d.php?t=695699
csfields is offline   Reply With Quote
Old 08-21-2014, 10:04 PM   #8
Fitz
This is one of those things that you really should not try if you do not know exactly how to do it and have the experience to do it right. A frame is a bit tough to fix once it's botched and your truck won't be worth much until it's done correctly.
Fitz is offline   Reply With Quote
Old 08-21-2014, 10:53 PM   #9
SierraMtns
SierraMtns's Avatar
This info might help you. Gives you an idea of what your getting in to.
I think anyone can do the job if they take their time.
http://www.powernationtv.com/episode...6/in-the-weeds
http://www.powerblocktv.com/episode/...r#.U_avVUgab-g
SierraMtns is offline   Reply With Quote
Old 08-21-2014, 11:56 PM   #10
Sklptrljay
Sklptrljay's Avatar
Dang, that looks nice!
To go back to the original issue though:
Because I'm a moron , I decided AFTER I painted my truck it still needed to be lower, making a c-notch necessary. I didn't want to remove my bed so I did it while it was still on. Anything is possible. Just take your time and it will all work out.
1971 C/10 SWB, 15x8 Rallys, 4.5" X 7" static drop, C-notched, 350/350, 3.73 Posi. .........A 383 and Gear Vendors are on my bucket list.
1972 GMC 4X4 K1500 Survivor - Sold
No matter what problems life throws at you, your time on Earth can be incredibly fulfilling and rewarding.....if you just lower your expectations. -Phil Dunphy
Sklptrljay is offline   Reply With Quote
Old 08-23-2014, 10:08 AM   #11
c10 custom
thanks everybody for the responses i got the job done looks good now i just need to install
the deluxe trac bar and i am good thanks again i appreciate it
Old 08-23-2014, 08:39 PM   #12
sduckworth13
Good deal, let's see some pictures now please
Scott
