Old 08-21-2014, 01:56 PM   #1
Cpa55
1966 Frame question
I have a 1966. What other years have the same frame. Is it only 1960 to 1966? I'm converting from LWB to SWB. Thanks for any help!
Cpa55 is offline   Reply With Quote
Old 08-21-2014, 02:27 PM   #2
Slow Build
Slow Build's Avatar
Re: 1966 Frame question
63-66 have the same frames basically. The 65-66 have a little different trac bar mount. 60-62 have an X frame with torsion bar front suspension and it's wider.
Current Ride: 1964 C-10 Short Fleetside
Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe
Past GM Trucks:
1959 GMC short stepside
1968 GMC short stepside-4x4
1973 Chevy short stepside
1989 Chevy short fleetside-reg cab
1993 Chevy short fleetside-Xcab
2002 Chevy short fleetside-Xcab
Save the dinosaurs, use synthetic oil.
Slow Build is offline   Reply With Quote
Old 08-21-2014, 02:27 PM   #3
LVPhotos
LVPhotos's Avatar
Frame change came in 63. Why not cut down the one you have? Lots of threads on how to do it and No Limit has a conversion back half.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline   Reply With Quote
Old 08-21-2014, 03:21 PM   #4
1963c-10
1963c-10's Avatar
Sorry....I totally messed that up. For some reason I was thinking seat frames......as mentioned above 63-72 frames are pretty much the same minus 65-66 track bar difference and frame horn on the 67-72.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 08-21-2014, 07:18 PM   #5
Lugnutz65
Lugnutz65's Avatar
1966 does not have an e-brake cross member. In 1966 they started using a newer e-brake cable design. People who upgrade transmissions often convert to the 1966 e-brake design because they need to delete the earlier style e-brake cross member.
The photo below shows my 1965 short frame. The 1965 e-brake cross member is the large flat black bar seen in the photo and marked "disregard". I have mocked up some 1966 e-brake pieces that include a rod, a cable, and 2 cable guides. The photo only shows some of the pieces. Basically, it does away with the cross member.
My 65 C10 build: www.lugnutz65chevystepside.weebly.com
Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild.
Lugnutz65 is offline   Reply With Quote
Old 08-22-2014, 01:52 AM   #6
Captainfab
60-66 Nut
The '63-'66 frames are easily interchanged. The '67-'72's will work, but there are a few things that need to be changed. When you change frames you get into possible legal issues with having a frame and body with different VIN's. I would just shorten the original frame. If you do not have the capability to do the job correctly, find someone that does. Cutting and welding a vehicle frame is something that has to be done correctly and with very good welds. If you must change the frame, check with your local DMV to see what is needed to make it all legal.
