Which LMC fuel fill hose/vent hose do I need?
I have an 84 chevy 4x4 3/4 ton longbox that I am replacing the fuel tqnks on and I ordered fill hoses and vent hoses for them and ended up getting the wrong ones for the pass side. I got a 32-3306 fill hose and its correct and it will work on either side it looks like. I also ordered a 32-3314 vent hose and its the correct one for the driver side but I'm not sure which vent hose I need for the pass side. The pics and descriptions on their web page are a bit confusing. Anybody know the right part number for the pass side vent hose?
#2 | |
![]() Join Date: Oct 2010
Re: Which LMC fuel fill hose/vent hose do I need?
2017 Silverado LTZ 6.2 1984 Scottsdale K10 - 468 700r 4x4 lwb 1978 GMC Sierra Grande K15 350 Soond to be 406 th350 4x4 swb 1968 GMC 20 305 V6 good ole wood hauler. ![]() Good Fences make good neighbors |
mine are 20 gallon tanks
I ordered both hoses, for both sides of my '87 crew. One was right, the other was not (don't remember which one was the right one?). But it looked to me that it should be the same fill hose and vent hose for both sides?
it wasn't worth it to me to try to return the hose, but I did order a second set of the good fill hose/vent hose. Fast forward a few years and I end up ordering the same thing for my '91, and again, one was good and one was not, and it appeared that the hoses should be the same for either side. The fill neck on the tank is in the middle of the tank, so the length and angle should be the same? LMC CS was of no help in either situation...
2009 Honda Fit CfC (bsf 44.9 mpg) 2000 Tahoe Limited 1991 GMC CrewCab Dually 2wd, will end up swb, not dually and replace CCswb below 1991 GMC CrewCab Dually 4x4, just going to fix things up for now 1982/1989 K5/GMC Jimmy 2wd 1987 GMC 1/2 ton swb 2wd Crew (sold) |
The tanks are the same configuration and not mirror images and the fill hose will work on either side but the driver side vent goes around on the back side of the fill hose whereas the passenger side vent is shorter with a tighter radius and runs in the front side of the fill hose. The 32-3314 is correct for the driver side, the 3315 looks like pic #6 in the 73 to 78 section, its a straight hose with a 90 bend on one end. The only other choice in the 80's section is a 3312. I am going to call them and see if I can get a pic out of them of the 3312, any bets they will tell me to go jump in the lake?? LOL
| Bookmarks |
