Restoring it $200 at a time...
Solid wire welding w/o gas?
I'm done with flux-core welding on the 110V Lincoln, but haven't pulled the trigger on the changeover yet. Until then, can I run a solid wire without gas? This is for sheet metal work only and it doesn't have to be pretty.
Charter member of the 'Put the dimmer switch back on the damn floor where it belongs' Society '68 5.3L-4 speed LWB C20; grandpa bought it for the farm in '71. Now LS 5.3, rather than 327. DD '09 Pilot Weekender '65 Skylark 300-4V-4 speed Wife's '07 Lexus ES350; 117 actuator motors and I can't see the engine. Son's '04 F250 SuperCab 6.0 |
Re: Solid wire welding w/o gas?
no
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
i second that..... no.
wont work you have to use flux if you dont use gas
flux you have to change the polarity on the welder and reverse it if you use solid so cant be done
#6 | |
#7 | |
When you are using flux core wire, the flux in the core vaporizes and shields the weld puddle from the atmosphere. When you are using solid wire you need the gas to shield the puddle from the air. With no shield, it won't work.
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
The gas simply dissipates the O2 in the air so that the weld can cure properly. The Flux in Flux core wire does this in place of an external co2/argon supply.
