08-21-2014, 07:58 PM | #1 |
Flarestat 105 Flasher info?
I pulled this today out of a mid sixties C30 truck. Hard to see but it has the 3 Chevrolet bowties on the red pull knob and the chrome bracket was attached to the left underside of the dash. I'm curious if this would have been factory or an optional item added later. Looks like the backside of the plastic terminal is where the actual flasher itself plugs in?
http://i224.photobucket.com/albums/d...ps3a735c0f.jpg http://i224.photobucket.com/albums/d...ps0afca164.jpg Probably not something I will use on my current truck, just thought it was a cool item.
1962 Impala SS 383 stroker Tremec TKO 600 Black 1965 SWB BBW Fleetside Custom Cab PB Coilover setup Black 2003 100th Anniversary Road King Classic Silver Black |
08-21-2014, 08:14 PM | #2 |
Re: Flarestat 105 Flasher info?
Option on C10's. A lot of big trucks had them and some passenger cars used the same. They are avail on Ebay also.
08-21-2014, 09:07 PM | #3 |
they can be pricy from other places then the forum thou, and i even seen "new" version with GM logos and the old style boxes go for a couple of benG's
08-21-2014, 10:42 PM | #4 |
1961 crewcab
if you can, get the other end of the harness, it has a specific plug that will plug into the junction of the column harness (turn signal harness), and will make life a whole lot easier when hooking it back up.
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
08-22-2014, 04:44 PM | #5 |
Could have been factory ordered, dealer installed or PO installed. There are quite a few different knobs that will help narrow it down. The red knob with the 3 bowties is correct for the trucks. Heres a good pic of the correct knob on the flarestat 105
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
08-22-2014, 06:54 PM | #6 |
That is what my knob and bracket look like. Thanks.
08-22-2014, 08:02 PM | #7 |
i have the knob type that has bout 10 white lines on the bottom side, maybe impala. do they sale just the knob anywhere?
08-22-2014, 08:25 PM | #8 |
Yes....they run around $50 from a guy on ebay. Only source ive found..may be others, just the only one ive seen. Ive got his info at work and can get it to you if you want. The pic I supplied is one of his gm cert. parts.
08-22-2014, 08:25 PM | #9 |
He has the chrome mounts also...I think he said $50 each on those too.
08-22-2014, 08:30 PM | #10 |
08-22-2014, 09:00 PM | #11 | |
http://i224.photobucket.com/albums/d...ps65deaf8e.jpg
08-22-2014, 10:41 PM | #12 | |
1961 crewcab
08-28-2014, 09:01 AM | #13 |
GMC version I installed on my '60
http://s1299.photobucket.com/user/jb...23904108567829 |
08-31-2014, 09:07 PM | #14 |
I'm going to post this in the classifieds on here.
09-01-2014, 09:25 AM | #15 |
I know in 66 models they did not use the red knob with the bowties
