08-21-2014, 08:45 PM | #1 |
Ho 52 housing swap
Hi I've posted on here in the past about HO 52 swaps. I'm planning on doing it over this weekend and was wondering if the full floater eaton needed to be shimmed. If so any method recommendations?
Thanks Andrew |
08-22-2014, 11:23 AM | #2 |
Re: Ho 52 housing swap
If you're just changing the jug, no.
68' C20. 283CI w/55CC 305HO heads, NP435 Close Ratio, Corp. 14 bolt FF 3.21, 75' front end swap (everything but the X-member). |
08-23-2014, 10:48 AM | #3 |
Haha I don't know exactly what you mean by jug, but my plan is to pull the rear drive shaft and unbolt the 4:56 ring and pinion as one then slid the 4:10 set I have back in its place.
