I saw a '76 3/4 ton chassis for sale for $200, so I thought I'd pick it up; disk brake front end, another 14 bolt rear with good leaf springs, some extra wheels, etc.
So I hooked up the trailer and drove the 40 miles or so to Rome, GA. No problem at all running 60-65MPH with the 4.10 gears (still need to kick the exhaust out in front of the rear tire to get rid of the loud droning, though). The truck then really came in handy dragging the chassis out--and I do mean dragging! Both rear wheels and the right front were locked up, so rolling was out of the question. ![]() The chassis was also in a bad spot, so a little thought was required. I turned around and unhooked the trailer, then used the fabulous low first and reverse of the SM420 and the grip of the remolded mud tires to climb up the gravel hill where the chassis was and play tractor. I drug the chassis down the hill and behind the trailer for loading, then drove back around and hooked the trailer back up. It would drag it along at idle, which was also kind of neat. Easy work for the junkyard work truck! ![]() |
Re: Got to use the truck off-roading and towing today (bought a '76 chassis)
I also swapped the hubcaps over real quick.
Hubcaps look good on there .
the caps look good on that black truck
![]() Join Date: Sep 2011
Nice to see a truck working like a truck.
Past Master Triluminar Lodge #117 GL of WVa My 1963 4x4 Suburban build; http://67-72chevytrucks.com/vboard/s...d.php?t=531274 My Gallery, now with pics of my 1966 C30 motorhome. http://67-72chevytrucks.com/gallery/...&ppuser=103447 |
Glad to see somebody snatched that thing up. $200 is dirt for that!
1982 K10 SWB 1987 V20 - Sold - Doh! |
Thanks guys. I also like the hubcaps; adds a little bit of much-needed contrast IMO.
And yes, this truck is still a truck. ![]() |
But Found Her 25yrs Later!
![]() Join Date: Oct 2010
Man! Your truck is cool.
Longbed Stepsides were considered so dorky when I was young. Now they are so nostalgic as a grandpa's old worktruck. Love it!
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 |
Nice score!!!
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
Thanks again, guys!
The more I look at your truck the more I think about not parting out the 63 long step
Post Whore
![]() Join Date: Mar 2013
I thought something on yer rig looked different when I was reading through my build and saw yer new avatar. lol Nice!
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
#13 |
Thanks! Planning on some more stuff in the very near future; the rebuilt 292 to replace the 250 should be going in shortly, the nice and tight disk brake front end, and possibly a 3.73 geared 14 bolt with the HD dually springs (supposed to be going to pick up some 3.73 gears and other misc. stuff for $20 Monday).
I'm also going to take the cab off to fix the rust/damage and put C10 cab mounts on it to replace the shot-out C20/C30 sheer-type mounts soon (after I fix the Impala I bought so I can drive it while the truck is in pieces ![]() |
