Old 08-21-2014, 11:37 PM   #1
72step
72step's Avatar
what size bolts for bed strips??
I'm going to be doing my own bed floor out of trex composite and was wondering if I can just pickup all the carriage bolts at the hardware store? If so what size?? I think the angle strips bolts are a size bigger??? Thanks!
72step is offline   Reply With Quote
Old 08-22-2014, 05:42 AM   #2
donthekawguy
donthekawguy's Avatar
Re: what size bolts for bed strips??
Are you using new strips or original? The new ones will use carriage bolts and the original strips use a bolt with with vertical grooves in it. Not sure on the size you need but get them at least an inch and a half long. One of the problems I ran into was some of the bolts were too short to use a washer on when the others fit fine. There is a lot of variation in the bed. Plus the kit I got was missing some bolts. lol
66 shorty
donthekawguy is offline   Reply With Quote
Old 08-22-2014, 07:28 AM   #3
PGSigns
PGSigns's Avatar
1/4 20 X 1 1/2 and 5/16 18 X 1 1/2 is what is in mine. Factory 5/16 bolts are carrage and you will need to look at the bed strips. Do a count and look for a local bolt supplier. Will get a much better price than a hardware or box store.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 08-22-2014, 08:41 AM   #4
1963c-10
1963c-10's Avatar
And if you get stainless steel...you can easily polish them up at home and save a ton of $$.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 08-22-2014, 11:25 AM   #5
72step
72step's Avatar
Thanks for the info guys. I was looking at my bed strips last night again and they have rust and those grooved bolts I had to cut off are all stuck in there. Then I did kinda messed up the angle strips a little when I was dealing with those rusty bolts so I'm just gonna spend a little money and get the stainless bolt kit and stainless angle strip covers and stainless unpolished strips. Might as well put a more permanent solution onto composite which will make my bedfloor 100% maintenance free. This bed floor business is a lot of work and I only want to do it once. Thanks....Matt
