08-22-2014, 01:35 AM | #1 |
Encountered a big problem with suspension..need help
So I was in the middle of jacking up my 68 c10 to chnage outthe pitman arm and noticed the grommet or flange that goes around the top of the shock broke off and the previous owner let the shock sit in the hole like that and now has flared out a bigger hole.
now my question is..i will eventually chnage into a lowering spindle and do a disc brake conversion. will the new spindle and conversion require differnt hole mounts? do i need to fix this or will it require a new hole anyways? thanks |
08-22-2014, 02:43 AM | #2 |
Old member
Re: Encountered a big problem with suspension..need help
I would say fix it. My 71 is lowered and it uses the same mounting spot.
08-22-2014, 05:32 AM | #3 |
You can use a shorter shock when you lower it and weld up that hole and install a new shock stud, or, you can use the same size shocks and use new upper shock mounts which weld to the frame and raise above the frame, are much stronger, look ‘custom’ and are a better way in the long run.
tubbed 1984 gmc jmmy http://67-72chevytrucks.com/vboard/s...d.php?t=639738 Alice Hombre http://67-72chevytrucks.com/vboard/s...d.php?t=808454 |
08-22-2014, 08:47 AM | #4 |
a very common problem with these trucks// take a large washer and weld it in place to get the shock functional again
08-22-2014, 10:57 AM | #5 |
I agree, weld it up. Then get a set of shock relocators.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
08-22-2014, 12:48 PM | #6 |
Who sells those shock relocators?
My Trucks: 1967 Chevrolet Short Wide Box 327 TH350 9" w/3.90 gears paint will be White - Current Project 1967 Chevrolet Custom LWB 283 TH400 3.73 Posi, no-AC, no-PS, no-PB, bench-seat, small-window - mostly orig driver 1967 Chevrolet CST LWB originally a 327 TH400 3.73 Posi AC PS PB, had Buddy Buckets, Small Window - parts truck 1967 Chevrolet CST LWB, 283 MT 3.73 had Buddy Buckets, Panoramic Window - parts truck 2001 Chevrolet 3500 2WD Crew Cab Dually 8.1L Allison White |
08-22-2014, 01:05 PM | #7 |
Old member
I bought a set of them and never used them. They are almost impossible to install if your not going to take the motor and fender's off the truck. I got mine off E bay. Performance something.
I was going to bolt mine on though. Drilling the holes was going to be impossible. I'm still planning to use them just going to wait until I have to take the front end apart.
08-22-2014, 02:04 PM | #8 |
Cpp sells em on e bay
1967custom |
08-22-2014, 07:32 PM | #9 |
You could always fab up something similar that will install without removing everything, like this http://67-72chevytrucks.com/vboard/s...postid=4730005 More than one way to skin a cat. I had the same issue welded a piece of metal in there and drilled a new hole. Not too hard to do, and works just fine.
08-23-2014, 03:48 PM | #10 | |
08-23-2014, 04:55 PM | #11 |
I had my motor out and placed a piece of 1/4" steel on the inside of the frame and welded it in. Then welded up the outside to the 1/4" filling in the gap. Then I put some brackets off a 4x4 that go to the outside end of the shock bolt to further solidify the whole mess.
I am not sure why GM didn't do this to start with but I think it's darn solid now!
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
