08-22-2014, 06:34 AM | #1 |
72 rear axle ratio question
Hi Guys
My truck has a 72 frame and components, took the rear axle cover off to find the gear ratio. It appears to be a 4:11. This is a part number off the ring and pinion. part number is #381778 11:4 GM Seems that a 1/2 ton two wheel drive long box would come with a 3:73 rear end. Mike |
08-22-2014, 10:16 AM | #2 |
20' Daredevil (Ret)
Re: 72 rear axle ratio question
Different gear ratios could be ordered back in the day, not to mention changed by previous owners. Best way to know for sure, with the cover off, is to count the teeth. Divide the teeth on the ring gear by the teeth on the pinion gear to get the exact ratio.
08-22-2014, 11:36 AM | #3 |
You could jack it up, spin the drive shaft 1 revolution and see how much the wheels spin.
08-22-2014, 05:19 PM | #4 |
If you look a little closer I bet it says 381778 11:41GM on the ring gear. This means 11 pinion gear teeth, 41 ring gear teeth. 41/11= 3.73. The original gears had these part number/ratio stamping.
Dan <---(my name) 67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car |
08-23-2014, 08:02 AM | #5 | |
Mike |
