Old 08-22-2014, 06:57 AM   #1
WOLFMANmike
WOLFMANmike's Avatar
i want to sit lower in my 65 c10 with my tank still in the truck
hello i want to sit lower in my 65 c10 long bed as in i would like the tops of my legs lower from the bottom of the steering wheel that they are now in a stock seat so i guess you could say im looking for a lower profile seat would be the right words maybe .... so if any of you know what kind of seat i should be looking for and might have pics of what it looks like in these trucks all info will be appreciated including any type of modifications needed cutting welding anything ... i have just got to get lower down and soon lol
WOLFMANmike is offline   Reply With Quote
Old 08-22-2014, 07:10 AM   #2
PGSigns
PGSigns's Avatar
Re: i want to sit lower in my 65 c10 with my tank still in the truck
My 65 came with a ford seat in it and it was on 2" blocks to get it tall enough. Have no idea what year it came out of but I think it was early 70's. There is a seat thread that shows lots of seats from other donor vehicles that may be of some help.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 08-22-2014, 07:16 AM   #3
PGSigns
PGSigns's Avatar
The 88 t0 98 seats fit and sit a little lower also.
Jimmy
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
Old 08-22-2014, 07:23 AM   #4
WOLFMANmike
Hi thanks where do i find this seat thread at on here ?
Old 08-22-2014, 10:31 AM   #5
newbe351
http://67-72chevytrucks.com/vboard/s...d.php?t=588074
http://67-72chevytrucks.com/vboard/s...ighlight=seats
newbe351 is offline   Reply With Quote
Old 08-22-2014, 11:14 AM   #6
luvbowties
luvbowties's Avatar
Smile Re: i want to sit lower in my 65 c10 with my tank still in the truck
The 3rd seat in Suburbans, Escalades, maybe Yukons & Tahoes are thinner in the butt & back areas and sit quite low in design as well. Seen a couple installed in our years on 'net pictures & they look like they offer great room where you are asking for.
Too bad we are not close, as I bo't a set when gathering potential parts for my '66 as I was planning for the build--ended up not using them. Two good things about them: lotsa people NEVER use this 3rd seat, so they often are just like new, and they have built-in shoulder belts. Many even remove & store them to make room for hauling. They come in leather and cloth.
Only con I've noticed is they are potentially on the narrow side. Nonetheless, mine are quite comfy just dry-sitting them on my garage floor. I'm still tempted, at times, to make mounts for them & at least try them. I am only 5'7", but have heavy legs & would like more legroom 'tween seat-top and steering wheel-bottom, even with the tilt st. wheel--I love to drive at times with wheel tilted way low, even in wife's mini-van, Z-28, & ext. cab Sonoma. **Tilt with telescoping would be even greater!
HTH,
Sam
luvbowties is offline   Reply With Quote
Old 08-22-2014, 11:50 AM   #7
luvbowties
luvbowties's Avatar
Here's some pics that may give you an idea as to size. Other one is essentially the mirror image. When making brackets, front could be brought down even a couple more inches.
sam
Old 08-22-2014, 08:00 PM   #8
Cooper197
Cooper197's Avatar
Take the bench out and look at the mounting brackets. If I recall correctly it should be easy to simply cut them down.
Though the 3rd row seats are also an excellent idea. Added safety of a 3 point harness. I used the front seats out of a 2003 Tahoe in my truck. Leg room got smaller, but the seat height is adjustable, and does go lower than the factory seat, but probably only about an inch lower.
Cooper197 is offline   Reply With Quote
Old 08-23-2014, 01:56 AM   #9
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
West Sac = Almost Woodland
My home town.
66 C20 Service Truck:
Old 08-23-2014, 04:42 AM   #10
WOLFMANmike
great guys thanks for all the great help
Old 08-23-2014, 09:54 AM   #11
TopFuel1966
TopFuel1966's Avatar
This seat came out of a 95 C-10.
TopFuel1966 is offline   Reply With Quote
